Went out on the G-Cat 5.0 today and had a blast, 15 mph winds, perfect. G-Cat turns out to be a very wet boat, flipped it once, pointed the mast into the wind, threw righting line over upper hull and she came up easy. Luv the rudder setup on the G-Cat, easy up, easy down, and they clip on/off for easy trailering. Put 10" wheels on trailer and it pulls so sweet, used less than 1/2 tank gas for 150 mile round trip to MTL, awesome, used to use 3/4 tank. The trap shock cord runs through the center beam on the G-Cat and that does not work as most of the time you are trapped off the back of the boat, need to run a shock cord through the aft beam. Biggest problem is still the fixed rotator arm on the mast base, have decided to cut it off and replace with a SS folding rotator arm, so that I can flip it out of the way when stepping the mast. Other than that, very pleased with the G-Cat all in all.
TurboHobo
H14T
P18
P16
