Many of you have helped me formulate how I'm going to do the hull repair and bottom job on my N5.8...invaluable advice and thank you to all for the time you have taken to help. I will pay it forward at some point in the future.
I've sourced the materials I need and am now trying to figure out the tools I'll need part.
1. I know I need a grinder. Is a 4 1/2" okay?
-I think a fellow member told me to use 60 grit to grind away the bottom fiberglass damage. Agree?
-Any other advice on this?
2. I suspect I'll need to cut out some damaged fiberglass. Should I just grind out the damage or do I need a reciprocating saw?
3. What kind of sander? Orbital? Belt? Both? What grits do I need for the various stages? (I will not be gel coating, but rather, painting...not sure if that changes the answer or not)
4. Respirator - a more permanent one that has replaceable filters? Or can I use the 3M disposable one that is cheaper and is worn out when you can smell the vapors? Not sure if one of these disposable types will be enough to complete both hulls.
Thanks in advance of the advice on this!
Jeremy Soder
Nacra 5.8
Allen, TX
