VS, it's all in the technique, righting a cat gets easier the harder the wind blows because we use the wind to help get the cat back up. Do
not fill the mast with foam anywhere, but
do make sure your mast is watertight, seal every rivet and join using silicone, next time you go sailing, drop mast in the water and check for bubbles, then seal. Do a search on this site for mast floats, there are threads on both home-made and commercial.
To right your cat, after you hit the water, compose yourself and take the following steps
1) swim over to cat and release main sheet from main block
2) release jib sheet from jib block (P15 has no jib)
3) swim to mast head and swim mast around and
point mast into the wind.
4) swim back to cat, climb gently onto hulls, grab righting line and lean out
some helpful tips:-
on my P18, I had a single righting line attached to the tramp through a grommet, make sure you have knots at regular intervals for grip, sometimes I loop line through harness hook to take weight off my hands.
it will take a while for the mast tip to break free from the water, depending on how watertight the mast is.
it will also take a while for the sails to break their cohesion to the water, this is where the wind helps, it will get under the sail and break it free fast, if you have a mast bob, the job gets easier as it hold the mast tip above the water surface.
once the mast and sails break free from the water, the wind will bring the cat up quick, so you have to be quick to drop into water and grab onto center beam to stop cat pivoting all the way over the other way as the wind will catch the sails and want to capsize the boat opposite side.
hold onto center beam and your cat will slowly face into the wind, you know the rest.
....and finally, practice, practice, practice, untill you look cool doing it..........
TurboHobo
H14T
P18
P16
