setup like so:-
1) attach pigtail (short upper forestay) to mast with bell shackle
2) attach swivel to other end of pigtail
3) attach furled jib to swivel (jib has wire in luff pocket which becomes your forestay, jib must be secured top and bottom to the forestay or wire will just spin in the pocket)
4) attach bottom of jib to furler
Hobie drum has 3 way adjuster already for some rake, if you are new to sailing that is all you need at first. Later you can order roller furling drum forestay adjuster......
... which attaches to the drum and allows you to rake the mast back more. Raking the mast is a technique used by racers to achieve more speed, but that comes after many years/hours of sailing, you will be ready for that in a little while but for now just concentrate in setting up H14T standard so you can gain experience.
Just remember this, tension on rig should be such that if boat turns turtle, mast base will not disconnect from mast step.
Make sense......
TurboHobo
H14T
P18
P16
