single hand H 16?
I have my H-18 up and going. I have stumbled on a nice H-16. I like restoring these boats and this one needs almost nothing. It's very reasonably priced. I need a boat for single handing as I cant depend on having a crew. What is the opinion of the H-16? I am low time cat sailor but it seems to come reasonably easy to me. I had much FJ time a hundred years ago. I am a 230 lb non slob.
Is this a reasonable single hand boat? Being as I have one Hobie, it seems sensible to go Hobie. I have started to learn the parts and pieces from the total H-18 resto I just finished. Maybe I am thinking wrong here?
82 Hobie 18 Alter Signature Model. (The Cisco Squid) Complete refit down to the rivets in 2012.
81 H-16
Rescue California
I (210lbs) and my fiancé (135lbs) both solo my h16 often. No problems here.
Nice quick cat for sailing solo, makes you want to "push the envelope", make sure you learn to right it solo...
Edited by turbohobo on Aug 23, 2012 - 07:11 PM.
TurboHobo
H14T
P18
P16
Shouldn't be a problem, after sailing the H18 the 16 will seem very small and easy to sail. At 230 you should be able to right solo, although try it a few times. With such low volume hulls H16 can sometimes be a trick to right.
Being in California, particularly Nor Cal, it seems that Hobie's are plentiful when compared to Nacra or Prindle boats. I did see one mid 80's Prindle. It was impressive in terms of fit and finish. Nice piece.
In terms of righting, what do you folks prefer for a rig? If I just need a big assd bag of stale water, I'll take the mother in law as crew. I put the Hawaiian style 5/8" coax type shock cord/rope on the 18. Have not had the chance to "try" it yet :)
Thanks for the help guys. I think I will score the 16 after doing a careful check for any dead spots in the hulls.
81 H-16
Rescue California
Check the decks just forward of the front pylons. Put your weight on them. I bought a h16 once that passed the tap test but delaminated as soon as I stepped on the hull. Luckily I only paid $200 for it and trailer.
will do. I have portable ultrasonic test equipment at my disposal. It is used for higher modulus carbon composites to check for monolithic lay up, but a value could be interpolated against a known good sample. Then again, it may be more simple to walk myself along the decks and feel it up. Low tech works more better most of the time. I will check it out carefully. It's green. Is that against the natural order of the sea? Like a banana on a schooner? Everytime I mess with mysticism, I get pranged right in the nuts.
81 H-16
Rescue California
you could get an H17. If it was me I'd solo the 18 but have to weight to be captain and crew.
17's are a bit more scarce around here. I guess I could bulk up and solo the 18. Im 7th gen Hawaiian. I am about 6 months of good eats diet and no work out to hit 3 hundred something!
81 H-16
Rescue California
When you say the H16 is "green", is it painted green or is the gelcoat green?....... icon_eek
TurboHobo
H14T
P18
P16
It was gel coat I believe. I have however found a nicer boat (creme puff) for a reasonable price. It has white hulls and is in fabulous condition. Actually needs nothing, which is amazing. Now if I can keep off the internet and let my visa card relax from buying accessorizing goodies that are completely non essential to sailing a boat, I'll be good!
81 H-16
Rescue California
astglennI have portable ultrasonic test equipment at my disposal. It is used for higher modulus carbon composites to check for monolithic lay up, but a value could be interpolated against a known good sample.
Was dat english? :)
No. It is the screwed up language that I have to use in my work life. I try to never use it in my fun life. It accidentally slipped out. This is why I stopped wearing shorts or trench coats. Slippage can be embarrassing.
81 H-16
Rescue California
Single handing a 16? icon_rolleyes
I single hand my 21SE in 10-15 mph wind all day long. icon_cool
I just need help stepping my mast ....and when the wind starts really blowing...I need my crew... icon_wink
Bill 404 21SE
bill40421SESingle handing a 16? icon_rolleyes
Seems like a good excuse to buy that life like inflatable woman I seen in....err. never mind. Wrong forum.
81 H-16
Rescue California
Hi astglenn I am in Livermore CA and have an extra H 17. I tiip the scales at a tenth of a ton + 20lbs. She stands up for me real nice. Bit of a project boat as she needs one wing tube fixed. Could be yours.. Hal (How was that Capt Bill.. Soft sell.. Yes??)
Hal Liske
Livermore CA
It's a Sickness
I Need a A Cat Please
Thank you for the offer Hal but I have committed to the 16 and pick it up tomorrow. If something goes horribly wrong, I will hit you up. A little broken tube don't worry me too much. I walk past a mandrel bender and TIG welding bench about 30 times a day.
81 H-16
Rescue California
smooth hal...like butter. "could be yours" is seductively suggestive! i give you an "A+"!
Bill Had some of that hooch that I make on board AND had just spent 2 hrs in the tasting room with 2 20 something hotties.. By the way, that hottie who you "almost talked into a sail" stoped by the winery the other day. Still in shock that you did not pitch a great pitch for a ride.. SOOO I gave him/her a bit different look with less red around the mouth (Tell tale lef-over stains on the skipper) and sharpened up the spikes a bit. So Take some sauve along for the cutts or wear a wet suit.. He/she is ready.. Cheers Hal.. P S Business is sloooo. Orical is in town with those 45s. Got a line on a used one so got to pratice up on my pitch.. "Only pitch poled once.. Spitthill loved it.. It comes with a nice wing.. Check out that hole there. The guy who fell through it signed it.". Yess?? Worth more bucks...... Yes!! ... MGB Rocks.. .. PBR.. Not so much H.
Hal Liske
Livermore CA
It's a Sickness
astglenn
Where are you in Cal North?? I got lots of H16 parts boats if you are in need.. Dont believe what Capt Bill might say. All my stuff is premo. Give me a buz if you want to head out.. I am retired and can do weekdays. Done H16s for 30 years. Yep Olde.. Could let you try my H17 as well. Email is .. sailing. (first name).(last name) at gmail. Drop a note when ya can.. Cheers Hal
Hal Liske
Livermore CA
It's a Sickness
Close to Folsom Lake. Union Valley is 1 hour up the hill. I need a good cat sailor that is up for teaching the seriously numb nutted! I am up for it! Thank you for the reach out.
81 H-16
Rescue California
