Hey Dustin, my thoughts exactly, the replacing of the tiller tubes was so well done I did not pick it up untill my new 4' rudder lines arrived, I had just finished redoing all the rudder sheaves and started feeding the lines only to find them too short, so I called Murrays for line length and they confirmed 4', so I'm standing there staring at the rudders trying to figure out what's going on when I notice a label on the bottom of the tiller tube, after I read label the light bulb flashed on, I step back and realize the tiller connector bar sticks out past the rear beam by about 8"-12". Will remove rudders, drill out rivets on end-caps, cut tiller tube to length, cut "V' notch, and re-rivet end-caps.
Just need a 2nd on that tiller tube length......no offense Peter........
TurboHobo
H14T
P18
P16
