It was the best of times, it was the worst of times...
Water is still near 80, air 86, sun's out, wind looks nice. Last nights forecast was for 30-50 clicks (30mph), but by noon both stations are showing 13ish, & the mid lake buoy 14.
My buddy is tied up driving #3 daughter off to start University, so I decide to take the 5.7 out, solo, with a plan to make Orillia-Cooks Bay return, appx 50 miles. It all starts well, but once I round the point, again the wind is stronger than the stations indicate.
I travel out a ways & enjoy the ride. Pretty soon I travel out some more, then more. What the Hell are these posts about letting out 6-8"? I'm now out past the hiking strap, & 1/2 the mainsheet gone too. Eventually I decide to abandon the line to Cooks Bay & just head down the shoreline, the wind is really honking, I'm a pussy & feel better staying in sight of land. Pretty soon I can't even hold that line, traveler is to the beam, lots of sheet out, blocks are 3-4 feet apart, & it still won't stay down, I have to increase pointing til I'm headed at Carthew Bay.
I get hit with a big gust, lifts the boat past 45*, then immediately drops it, hard. As I'm regaining traction another big one tips me nearly 90*, & with most of the sheet out, I don't have much in the way of quick power release. I'm hanging as far as I can, & pushing the tiller hard, but at that angle the rudders have almost no bite. We have come nearly to a stop, & just as I think it will come back down a final snotty gust administers the coup de grace.
Damn, I wasn't planning on swimming to day. Throw the righting line over & start to untie the bag. Make a mental note NOT to let go of boat, as we are drifting way faster than I can swim. This is happening with the mast still pointed dead DOWNWIND. Standing on bow or stern makes no difference, so I jump in & pull myself along the forestay to the mast hound & start swimming it around. I get it 1/2 way & figure it should swivel on its own now, so I get back on the hull & hike out, thinking I might not need the bag. Sure enough, in this wind, my skinny 170lbs is enough & it comes up. I grab the DS to prevent it going right on over, then realize I'm being drug, so fast I can't get my legs forward of the beam in order to monkey up the hull. The damn jib line has jammed on something & we are sailing.
After several tries, I realize it is going to remain current heading, I can't get my legs forward, & can't hang on forever. I take a chance monkeying underneath the tramp to the rear beam by hooking 3 fingers into the underneath of the tramp side lacing, & going hand over hand til I get to the rear beam. I can now hook both arms between the tramp & rear beam to hang on. With my legs being swept further back, I can get one foot on each side of a rudder & twist it enough to head up & stop.
I quickly get around the side, grab a shroud & trap handle, flip onto the tramp, then start sorting out the mess.
In a few minutes I' m screaming along, trying to spot the buoy marking the only nasty reef in the area. I do spot a bare mast, & as I get closer it turns into a small tri-hull, (Hobie sail, WindRider?)with a guy & his gal. He says they are OK, couldn't make out why the sail is down.
Conditions are getting worse, & the wind shifted, so I abandon the plan & turn for home, now a broad reach to make Home Bay. I've never reached in wind this strong, but hey, isn't a broad reach really stable?
With the traveler to the beam, the main way way out, not a single tell tale flowing properly & the GPS at 21 mph it is a very spooky ride. The gusts keep wanting to turn me over, there's almost nothing left to let out & the bows keep diving for China, thank God for those high forward flotation Nacra hulls.
My 5.7 is "nervous" at 20+ water speed, steering gets real twitchy. I'm standing on the very end of the hull to prevent a pitchpole, so far so good, the bows keep surfacing.
After about 5 miles of this I'm, feeling like I might make it. Then the Wind God slaps me uspide the head, & over it goes, in really slow motion, so slow I'm eventually trapped off the skeg. I finally give up, & step over the hull, clear the hook, & slide onto the sail, no way am I jumping clear & losing contact.
Wind catches the tramp & drives the mast down, way down, sh*t, the damn thing goes full turtle. This cannot be happening. This is really bad. My mast is sealed, BUT, there is no way to totally seal the rotator wishbone as the bolt fully transits the mast, & it is now underwater. I know full well that in a very short time there will be a gallon of water at the mast head, preventing righting.
As fast as I bloody well can I get the righting line over the upwind hull, across the tramp & over the bow of the downwind hull. It is more difficult than imagined to climb up an inverted skeg hull. I do it, move right to the tip of the bow, & hike out, wishing I had a few knots closer to the end of the line. It seems like ages, (enough time to think about how long will it take to drift to the far shore, while turtled, can I retrieve the radio from the pocket, which is now underneath, & am I in range of the Coastgaurd station)in reality probably only 30 seconds pass before it starts to roll onto its side.
I'm actually amused by the fountains of water squirting from holes in the beams
As it rolls I slowly move down the hull & keep pulling in line.
With barely a pause, the mast comes clean, so I hike harder, & up it comes...twice in one day sans righting bag, 2 points for big wind.
Again I scramble on board & sort things out. Downwind rudder has popped the pivmatic & steering is a bi**h. At least I've made enough way to round 8 mile point & now am able to point for our Bay. I try heading up to lock down the rudder, but it's jammed solid, fully up. I know it's the pulldown line jammed, but there is no way to free it. I need to get on the hull behind the tiller tie bar, & use both hands to push the blade down about 30*. This means letting go of the steering, & each time I try the wind grabs the hulls as they point skyward off a wave & the boat quickly starts to turn, nearly flipping it again. I decide to just pinch the 5 miles to the windward shore, this takes an hour. The boat makes significant leeway pinching & I miss the beach by 2 miles, but at least I end up in calm water thanks to the forest. There is a tiny clear spot with a rocky beach, so I essentially pull into someones yard. The owner is there in 10 seconds, asking if I need help, she has been watching me for 20 minutes, wondering why I'm going so slow. I pull the boat onto some smooth rocks & get the rudder freed. Her husband comes down & says he has seen our Cats, looks like tons fun, & so bought an old Hobie he is restoring for next season. Another Cat sailor, score 1 more point for the Nacra.
After a chat I head for home, misjudge the approach to the dock, have to pull up & go around. With little searoom I misjudge again, blow the tack & have to back down. Not good because the water is going to get real shallow real quick.
It comes about just in time. I make sure not fuck up the second approach, get it spun upwind in the shallows & walk it to the dock, drop the rags.
My wife walks out from the deck & comments about how much fun it probably was & how maybe she should have come, broken leg & all.
I'm thinking, that wasn't sailing, that was survival, you'd probably have two broken legs. But I did make 21 GPS MPH, solo on a 19' boat!
Edited by Edchris177 on Aug 31, 2012 - 09:45 PM.
