Recondition sail? Can this be done?
I have a plastic/mylar sail it is starting to delaminate in in a couple of areas. Is their a company that I can send it to and have it relaminated? or reconditioned?
Should I just purchase a new sail, this one has about 7 years FL sailing on it?
WILL icon_biggrin
Will
Indian Shores, FL
Newbie but catching on fast.
NACRA 17
It's time to replace.
Check with http://sailcare.com, if it can be done they can do it. They could not get the oil smudges out of mine, but the rest of the sail came out really well.
Mike Brady
Sugar Land, TX
P16 "Pooh Cat"
for a temporary fix, try this in the 'transparent' version. it looks a lot like woven mylar.
http://www.3m.com/brands/scotch/toughtape/
worked for me and i could hardly see it on the sail. again, it's probably only temporary if the sail is starting to delaminate.
i had Sailcare restore a dacron sail for me with good results but i don't know if they do mylar ones.
'99 Nacra Inter20 (sold)
27fountainI have a plastic/mylar sail it is starting to delaminate in in a couple of areas. Is their a company that I can send it to and have it relaminated? or reconditioned?
If it's only a small area you can try taping it down, but general delamination of the mylar from the sail body means it's time for a new one.
reward yourself with a new sail if you can afford it
new mylar (the outer layers of the sail) tech has improved a lot since your old sail was made and they typically don't scale off in slivers anymore... they just rip at the stitches or the fibers give out and tear. you can then be patched with new material.. but it is just delaying the inevitable... (need for a new sail)
If you want to have a sail for a decade or so... go with dacron. they will stretch and "blow out" (stretch and not be as efficient) but they will last for up to 20 years (see all the legacy boats with colored sails)
if you want a lighter / faster sail.. go with a modern cloth (pentex, kevlar, technora, load path, etc), and modern cut - technically these still use a mylar film on the outside for UV and abrasion protection.. but as i said.. the mylar of yesterday is no longer utilized
http://en.wikipedia.org/wiki/Sailcloth
Thanks for all the answers, I will utilize the 3m tape for a temporary fix (if needed), and begin the adventure of a new sail. I actually deep down was wanting a black sail??? Just couldn't justify until the one I have wore out, I think I may be there. icon_razz
On a fun note I pitch poled my boat yesterday for the firs time, actually couldn't right it until a friend came over and helped icon_confused
WILL
Will
Indian Shores, FL
NACRA 17
my new main (from doyle in st pete) isn't black, but it's pretty dark...
http://www.israeltour.com/images/new-main.jpg
The darker the sail the hotter it gets. Go with a lighter color for a longer lasting sail..
Doug Klem
Pensacola , Fl.
Blade F16
Prindle 18-2 w/spin
Prindle 18-2 x 3
Prindle 19 MX
MN3 but as i said.. the mylar of yesterday is no longer utilized
does this even apply to the colored dacron/mylar sails? I really like your sail, but i gotta have some colors icon_razz
There is color options for laminated sails. Here is my new jib
http://i46.photobucket.com/albums/f149/black92se/BADE18E9-4C0F-418A-9C67-0C763DD541F4-280-00000014D9E3031F.jpg
Mn3
I like your sail, it doesn't have to be black, but similar to yours with maybe some trim colors, it their a website for doyle in st pete??? I am very close to st pete icon_biggrin
Will
Indian Shores, FL
NACRA 17
bachoThere is color options for laminated sails. Here is my new jib
Is Dimension-Polyant the only sailcloth manufacturer with the new funky colors?
Do you know who made the blood-red (ish) pentex used on one (or more) of the wildcats?
Rob
OKC
Pile of Nacra parts..
