We just purchased a G-Cat 5.0 that is going to require some work before she sails. From what I have read she sounds like a lot of fun. I have never seen one of these boats before so I need as much reference as I can find.
I have some questions -
1) Does anyone have a rigging diagram of this boat that is high enough resolution to print?
2) The rudder assembly is really trashed and will require a complete rebuild. The starboard bracket is all broken up at the top, there is no tiller and hiking stick assembly, and both rudders had the metal plates that pull the rudders up ripped out. Does anyone have a full rudder assembly for a G Cat 5.0 for sale or know where I can get one?
3) The mast base was also destroyed, it is currently just a piece of broken Aluminum with a hole in it. Does anyone have one of these for sale?
4) Why is there a long point in the pictures I see of the mast base, is it for a boom vang?
4) The deck joints on both hulls need to be reset. I was going to squirt 3M 5200 up into the seams, will that suffice?
On a positive note, the hulls are in excellent shape. There is a little bit of a soft area on each of the pontoons, but those should easily fill in with injected epoxy and neither of the soft spots are in particularly nasty places. The trampolines and standing rigging are in good shape (other than the mast base) and it appears that all of the running rigging is there. The sails are in decent shape and should be good for a couple more seasons at least.
Thanks for your time,
Alan
Edited by spiritsailor on Sep 30, 2012 - 10:22 PM.
Simple is Good
