The stay needs to be tighter than the downhaul tension on your jib, otherwise the jib ends up taking the load, instead of the stay.
I used to tighten mine by undoing one side stay, & hike out in a harness, then have someone put the pin in. You can gainone more hole by "bouncing". NAcra says, not so tight as to impede mast rotation.
Have a look through my album for setup photos.
http://www.thebeachcats.c…e287a81e0c1bc804b60d55d9
