Do some reading on fibreglass repair, lots of info at your fingertips via Google. Lots of threads on this site, use the search function, & look under Albums-Technical.That will get you informed on what you need for materials, & how to go about it. West System has some good info.
http://www.westsystem.com/ss/the-105-system/
Here is a thread, smaller hole but same basic idea for the fix.
http://www.thebeachcats.c…ms/viewtopic/topic/13879
Here is an album Christian made to document the fix.
http://www.thebeachcats.c…ictures/?g2_itemId=91098
What I did to fix a leak, I ended up grinding a hole about 2" to get rid of the damaged material.
http://www.thebeachcats.c…ictures/?g2_itemId=77105
You should be able to fix it for $100, & have plenty of material left over for the next time!
