I have an Aussie halyard system that I think might be homemade or scavenged. It is from an 07 Hobie that was part of a rental fleet in GA. I suspect that the parts might be swapped with other boats, or some of the parts 'homemade'.
The issue is the Aussie halyard. The forestay is shackled to the top of the halyard block, which is then connected to the mast tang by a short pig tail. I believe that, after a day's sail, when striking the sails by releasing the tension on the halyard, the halyard block pinches against the now tensioned forestay, and prevents the free running of the halyard in the sheave. I have to use most of my weight to pull down the sail.
my question is should I add a pigtail as shown in this picture from a Murray website? will that cure the problem?
I also have this pic from the Hobie catalogue
It indicates that maybe the halyard shipped from Hobie is longer? is this the case?
a second issue, maybe an issue, maybe not, maybe related, maybe not, is when i stepped the mast for the first time, I had to put the shrouds on the last adjustment of the shroud adjustment plates, and the forestay close to its end, as if the wire ropes were not long enough. Could this be related? I think the boat had sat for a season or two before I purchased it.
Ted
South Carolina Lake sailing
