Posted: Nov 24, 2012 - 06:49 AM
Thanks for the info. The 5.0 is an '89. The measurements are 5" larger, leech & luff, 1" on the foot. I stretched out the 5.7 on the driveway, & came up with 210x201x78. I have a newer jib for the 5.7 that is larger than that, maybe they also made the later 5.0 with slightly more area.
Our season is over, boats are put away, I did get 40 days on the 5.7 this summer, & did a couple of 50 mile jaunts to the other side of the lake.
Any time I log into this site it shows if there are new messages, in the top left corner, just below the "home" tab. It won't show up though if you are just reading & not logged on.
You can change a setting in your profile so as to give you an email when you get a PM.
Click on MEMBER PANEL,(near the top, just below Photo albums) then CONFIGURE PRIVATE MESSAGES, select YES.
Edited by Edchris177 on Nov 24, 2012 - 06:54 AM.
