late to this thread but i just wanted to add my 2 cents here.
i've had stripped threads in the hulls of a nacra5.8 and a nacra inter 20. in the 5.8, i drilled and tapped the insert for a larger bolt like Nacraman57, which worked fine in that strap system. but i just finished using a helicoil insert in the hull of the Inter 20 and i just want to say that it really worked well without a lot of trouble. took me about 15 min.
because of the unique (3/8"x 16 thread/inch) bolts thru the front beam of the Inter 20, which use an allen wrench to tighten them instead of a socket wrench, i didn't want to change bolts and try to find a larger one like it (good luck!) so i went to Advance Auto Parts and bought the kit which has 10 helicoils, a tap and a tool to insert the helicoils all for $23.
http://shop.advanceautopa…39-p?brandName=Heli-Coil
you have to enlarge the stripped out hole with a drill bit, then tap the hole, insert the helicoil, knock off a little tab on the helicoil and you're done. after i finished, when i tightened the bolt done, it really gripped tightly....tighter than the other factory bolts. i'm sold!
note: the kit did not tell me which size bit to use. for a 3/8" bolt, enlarge the hole with the next size drill bit, 13/32". be conservative and don't go too large in drilling the hole out.
watch some youtube videos on how to do this. they do a good job of explaining it!
j
'99 Nacra Inter20 (sold)
