a,
i removed some registration numbers and stickers from two of my boats during restoration and found the same thing.....gelcoat was raised above the rest of the surface and in much better condition. but why make the thicker gelcoat thinner by sanding? won't it be difficult to sand only the raised sections without overlapping the oxidized gelcoat, thereby reducing it's thickness?
if i were you, i would just start the polishing process. i used 3M Marine Rubbing Compound followed by 3M Finesse It II Glaze. i was able to bring back that old finish to nearly match the areas under the stickers. make sure you get a polisher and don't try it by hand....it will come out much better.
Collinite paste wax is good stuff and one 'can' will do several boats. (apply with an old 'whitey tighty') put on quickly over small areas making sure to rub it well into the surface. it is important that you DO NOT LET THIS WAX DRY before you buff it off or you will not be able to get it off. i made this mistake the first time. read the can. do an area about 2-3 s.f. and start buffing off at the beginning as it STARTS to dry. sounds odd but it works. you will know by the feel of your buffing cloth whether it's 'sticky' and not ready to be buffed.
you can see the numbers and finish here.....this cat was really oxidized to begin with:
http://www.flickr.com/pho…57628025362618/lightbox/
from most angles, the numbers don't show at all.
j
'99 Nacra Inter20 (sold)
