Removing old rubber from side rails
Im removing the nasty ol rubber from the H16 side rails with a chisel and goo gone.
Any better ways out there?
Thanks!
https://lh5.googleusercontent.com/-4dsMqntqDac/UWi76XuLbdI/AAAAAAAAAHM/D7B1AiZmJsg/s800/20130412_205505.jpg
I would suggest not using a chisel, it will gouge the gelcoat, get one of those plastic ice-scrapers with a solid edge. Unfortunately there is no short-cut to this type of miserable task, you just have to git-r-dun!!! You can try soaking a small area with acetone, let it sit for a while and then try removing the non-slip rubber. Once the majority of the rubber has been removed you can hit it with the goo-b-gone.
R
the-renovatorI would suggest not using a chisel, it will gouge the gelcoat...
I think this is aluminum trampoline frame not the hulls.
I would try scraper with sharp razor blade to cut as much rubber as possible. Then wire weel and goo gone to remove what is left.
Adam Bartos
SolCat 18 (sold)
Lake Zurich, IL
Good catch there Adam, I forgot that on the H16 the grip-strip is placed on the aluminum rails....... doh
Edited by the-renovator on Apr 14, 2013 - 08:09 AM.
