The downside Scott, is the mast ball will sit on an angle. If you analyze the forces, they will no longer be pushing the ball straight down onto the pin. The mast will not ride on the top, but biased to the side of the ball.
Am I correct in thinking that is a 9/16" rod, with a 1 1/2" ball?
I have a spare rod that I could lend you for the season, but shipping it back & forth is probably 1/2 the cost of a new one.
I would straighten it, you can bend 304 SS that amount with little loss of strength. Then use it for the summer, & have new one built...see my album here. (By the way, to post an image, right click the image then select "copy image location". Then click the 3rd tab, (IMAGE) just below where you are typing the post. That will insert a couple of brackets & IMG into your post. Put the cursor right between them & paste the link from the photo that you copied, voila!)
http://www.thebeachcats.c…ictures/?g2_itemId=73301
There are 2 ways to straighten, on or off the boat. The album shows how to get it off. If you elect to do it on the boat, you will need 2 extra nuts, & I mean the ones on the rod! They are 9/16" NF, I believe it is 18 threads/inch. Thread them on, & turn them down to 1/4" above the start of the bend. Line them up so you can place a deep socket over both of them. Place a long extension into the socket for leverage. Now comes the tricky part, you will need someone strong underneath to positively hold the rod, you should not use the beam alone to hold it. Go a little at a time, you don't want to overbend it, & don't look for perfection. It will bend to within a millimeter or two of true.
When you do go to replace the rod, you will most likely have to cut it. If the rod straightens OK, you MIGHT be able to turn the nuts off the top, but generally it takes very little bend to prevent that. There are most likely only threads 1/2 way down the bottom of the rod, so they won't come off that way.
If you get in a real bind, let me know,& we'll look into a loaner.
Edited by Edchris177 on Jun 04, 2013 - 08:11 AM.
