When tacking, the jib catches on its halyard. I thought my previous cat had a clip half way up the mast, on the side, that would hold the halyard off to the side and out of the way. Does this still exist?
I have read that people recommend putting tape over the battens, so they do not have any ridges to catch the halyard. I have also read recommendations to loosen the battens when not hoisted, which would make the tape trick time consuming.
What do you do to keep the jib from hanging up on your boat, or are you blessed with enough wind to let the jib strum that halyard?
Ted
South Carolina Lake sailing
