Main Halyard for Nacra 17
Ok, I need to replace my Halyard can anyone recommend the correct diameter and type of line to use?
2000 yr Nacra 17 Interfusion
Thank you
Will
Indian Shores, FL
Newbie but catching on fast.
NACRA 17
Ideally, 3/16" of "quality" double braid to minimize stretch. Low stretch single braid will work also.
I may name my boat the Interfusion.
Rob
OKC
Pile of Nacra parts..
Like Philip said, decent quality 3/16" polyester double braid is fine. I use sta-set (with something much higher quality for the spin halyard.)
Once the main is hoisted, the halyard bears no load, so no reason to go overboard on it.
Rob
OKC
Thanks purchased the following for $20 will rig this weekend see how it does?
3/16" (5mm) x 75 feet of Double Braid Polyester (Dacron) Line
Uses: Mainsheets, Halyards, Jibsheets, Control Lines, Tie-down rope, Utility Cord
Color: Blue with Gold Fleck
Tensile: 1,400 lbs.
here is link if anyone else is interested
http://www.ebay.com/itm/161004214276?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Edited by 27fountain on Apr 24, 2013 - 08:55 PM.
Will
Indian Shores, FL
NACRA 17
