Catamaran Speedometer
Hi,
A topic on speedometers (can't find it) made me figure
out this simple setup. Used the padle as a boom-extender
and a Garmin gps.
Yesterday I did a test-run, here's the result.
http://www.youtube.com/wa…detailpage&v=XALVwzZJs3Y
André
Tornado (80's Reg White)
Prindle 18-2 (sold)
Dart 16 (hired and hooked)
13 mtr steel cutter (sold)
Amsterdam, the Netherlands
Like it!
Same here! That's cool.
Tom Benedict
Island of Hawaii
Like it too. Is it reading kph or kts??
Jeff R
'88 H18 "Jolly Mon"
'10 C2 USA1193
NE IN / SE MI
cramsailing.com
rehmboLike it too. Is it reading kph or kts??
Jeff, its reading Knts, nautical miles.
André
Prindle 18-2 (sold)
I have an old analog speedo that was given to me with my H-18. Imagine a 3/8" aluminum pole with a plastic prop on the end. i tried it once, but the cat goes so fast i could barely hold the darn thing in the water.
HAHA, ANALOG~!
I think the proper method is to tie a line to your rear beam and drag your crew behind the boat. They can hold the pole/prop in the water below them much better than you can (their hands are free)
Every time they come up for air (i assume they will get dragged under often) they can yell the current speed reading to you (in-between their gasps for air)
rch701I have an old analog speedo that was given to me with my H-18. Imagine a 3/8" aluminum pole with a plastic prop on the end. i tried it once, but the cat goes so fast i could barely hold the darn thing in the water.
MN3I think the proper method is to tie a line to your rear beam and drag your crew behind the boat. They can hold the pole/prop in the water below them much better than you can (their hands are free)
I recall seeing a harness for keeping the crew and analog speedo under the tramp, out of the sun. I think there was an optional Playmate cooler rack/snorkle to add to the crew's comfort.
It had a light so it could be read after sundown as well.
Well done... I will be hijacking your setup idea. I will have to see if my LCD is readable 4 or 5 ft back tho.
nacra inter-18
CNBP
i did the same on my trimaran on the end of the bowsprit and a gopro3
http://www.youtube.com/wa…s45hdszGx0LqvYgQ&index=2
bernd
Maybe utilize a speedo like on a yamha wave runner. Has a 1" paddle wheel that spins that calculates speed and sends to a readable unit??
Will
Indian Shores, FL
Newbie but catching on fast.
NACRA 17
And attach to be k of a hull. Maybe one for each hull?
Will
Indian Shores, FL
NACRA 17
