Hey All,
Recently purchased a '95 Nacra 5.8NA. All in all a good boat for sure, but I am coming from a Hobie background and lots of experience on a catalina and a pearson (mono hulls....I know) and have a few questions.
The standing rigging was replaced 2-3 years ago by previous owner, looks to be in good condition. He had marked areas on the chainplates where to connect the shrouds and forestay (will link into the second question). The rig feels a little "sloppy", a bit loose. The bridlefoil sags with barely any tension to the forestay, but the mast is raked just slightly rearward when boat is on the level. Are these cats supposed to be loose without the sheets up? I remember going crazy tight with my old hobie 18.
Second thing is this boat has introduced me to roller furling. looks to be the murray's kit, with the harken roller at the bottom that most are using. There is a small section of the forestay at the top that has a swivel between the eyelets. (I have 2 of these, one that is about 2" shorter than the other, the longer one is in the rig now), below that is the longer section of the forestay, and separate is the narrow block with steel cable with bull shackles at each end. Attached to the steel cable is a thin rope which I am guessing the steel cable and rope are the halyard assembly. I feel that I am missing something brilliantly simple with the rigging of the jib, the forestay just seems too loose, when I hoist the jib on the "halyard" (or what I think is the halyard), I run the line through the zipper on the sheet, but I run out of room to the block at the top of the forestay. I do not think this is normal at all, and what is the downhaul for the jib when set up on furling?
I think if someone has a clear photo of the top of their rig (near the mast hound, but showing that top section of the forestay and block), and a clear shot of the base and how it is rigged at the furler, that would clarify some things for me, but any help or input would be greatly appreciated, possibly someone has experienced something like this and both situation may be from the same issue. Or maybe an idiots guide illustration is available somewhere, but I cannot find something that looks specific.
Patrick
