Don't worry about a "tight" fit. You only need the keel touching. Sloppy makes it easier to get the boat on the cradles when in the water. We built a set for the 5.7 & 5.0, (same hulls as yours) using the design of Fricker & Catsailor Mike. We had some 12" sections of 12" water main plastic pipe, cut into 1/3rd, it yields a cradle almost exactly like Mikes design.
As you can see, it is nowhere near the profile of the Nacra 5.7 hull, but it doesn't need to be. You don't need exact alignment to get the hull on the cradle, & once the weight of the boat gets on the cradle, it isn't going anywhere.
We rounded & sanded the corners of the cradle, friendlier on the shins. We also slipped a piece of PVC pipe over the axle, with a "T" in the center, as means of attaching a handle, makes it easier 1 man to utilize.
All in all, it does take a few hours to build, you are probably ahead if you can find a good set of Cat Trax with cradles for $300.
In our case, we already had the wheels, (for moving boat lifts) along with all the other required hardware & piping in the spare parts bins. The only thing we purchased was 2 PVC reducers, & 1 PVC "T".
Total cost, other than some electricity & beer was $3.99
