ya. after more experimenting I realized I need the becket on the bottom... do you think an added eyelet will suffice as a becket? Its for an H16 downhaul
If you mean putting an eyestrap above the camcleat, you may not have room for the tie off and the uncleated line in the space of the eyestrap but it's worth a try.
-- Ron
Brandon, Mississippi --
I don't see how you need either becket. Start at cam cleat, go up to triple (to the side), down to cam cleat triple, then up & down twice and DEADEND on last sheave of cam cleat triple (with simple knot not allowing go thru sheave.). Pete
Ok... the boat unassembled. It took ages and about ten million knocks and hits with a mallet to remove a tramp. No other problems. Shall the next summer be here soon
