Hey guys,
I noticed that the mast base on my H18 was creaking and moaning a fair amount so I pulled the mast base to inspect and found that the crossbar was deformed and there was a crack going from one of the mounting rivets to the hole for the dolphin striker. Earlier this year 2 of the other guys in fleet2 had to replace their xbar for the same reason. Couple questions:
1) Our local H18 expert recommends using the 2 rivet mast base since the rivet holes seem to lead to these cracks, but I also see Matt Miller from Hobie and others recommend moving to the 4 hole mast base
2) how do you tension the mast base? Is there a formula?
For the record, the current mast base is a 4 hole and the replacement xbar is a 2 hole. So obviously I have the parts to do this either way, I just want to figure out which way is better.
Any other tips/tricks/recommendations for how to fix this mast base?
Eric
