As Pete said, easy fix. To make it super strong, cut out a piece from a plastic juice jug, punch a small hole& run a bit of fishline through. slide 2 or 3 layers of fibreglass cloth down the fishline onto the plastic. Wet them out with resin, then tip it sideways & slide it through the hole, gently pry the hole open a bit if you have to. Pull the line tight, this will pull the patch against the inside of the hull, the plastic piece will hold it in place.
Once it sets up, you have backing, finish as Pete says. More time will be spent getting organized than the actual fix. Once you have the materials, it will be done in an hour.
Here is how i patched a similar hole in my Nacra. I used SS wire in that fix, but would use line instead.
http://www.thebeachcats.c…ictures/?g2_itemId=77105
The fiberglass work is really easy in this case. Just Google West Epoxy system, & do a bit of reading on how to go about the actual resin/cloth bit. Don't get hung up on buying measuring pumps, you can easily mix it in a small plastic container, (yoghurt cup etc) & count "drops" of hardener. Measuring resin accurately is essential. Use a small clear plastic container, measure water with a syringe por any other means of accurately measuring 1/2 to 1oz increments, then make a pencil or marker line on the outside of the container. Now you can accurately pour a known amount, & add the proper hardener.
If you can't beg, borrow or steal a small amount of additive,(micro fibers) PM me. You only need a little bit for that fix. I can mail you some for the cost of postage...but I'm not sure if the US Postal system(I'm in Canada) will send the CIA after me for mailing what looks like white powder
I have used 3M Bondo with good results. Some say it isn't waterproof, I disagree. I left a 6"x6" piece in the lake over winter, it didn't show much weight gain when measured on a scale that goes to 100ths of a gram.
Edited by Edchris177 on Jun 14, 2013 - 05:27 PM.
