Gudgeon replacement 5200 or not.
I just repaired my transom on my 5.2 (embarrassingly stupid). I am pitting my gudgeon on and was wondering, should I pit 5200 around the the gudgeon? Or should I use a silicon sealer around the bolts? I Any thoughts would be appreciated. I would love to finish today and sail this weekend.
Nacra 5.2
4200. You might want to pull it for some reason.
5200 is forever and almost never should be used.
Well I would hope this would be forever. That may be why I had a big chunk ripped out of the transom instead of just the backing plate. But do I want to place around the gudgeon or just silicon the bolts?
Nacra 5.2
4200 gudgeon plate. Tefgel or antiseize bolt threads. Bead of 4200 at bolt head.
Tefgel is amazing product
3 years after application (and around 450 sails in salt water) I recently replaced my broken dolphin striker and the assembly has multiple grades of aluminum + ss screw&bolts.... no corrosion - tefgel was a glob of yuck... but still there.
was looking for (unsuccessfully) my tube this morning.. as i was replacing an exploded washer on my rear beam ... had to settle for lanacote
