My recently purchased 2004 Nacra 570 has a Harken Ratchamatic 57C triple block on the main sheet (I believe it is a #2618). I've never had one before but from what I can tell the ratchet function does not seem to be engaging at all, even when sheeted in under heavy load. I checked the adjustment screw and it is currently set at 2 ¾ turns out from the bottom (2 ¾ turns counter clockwise). If I read the manual correctly I think I should move the screw out more to achieve engagement at lower force but I’m not sure how far out you can adjust the screw? I am not familiar with these blocks so I am looking for ideas on how to adjust or change the block so that it engages or maybe determine if there is a mechanical problem. I sent this message to Harken techical support but did not get a reply. I'd appreciate any personal experience or ideas you may have to offer.
Steve - Texas Gulf Coast
91 Mystere 5.0 (sold)
04 Nacra 570 (sold)
08 Hobie Wave
00 Taipan 4.9
