Purchased this '82 Hobie 16 and trying to learn to sail it. With help from this forum I have been able to correct some wrong rigging and basically get it into better shape. One proplem that I can't seem to correct is the inability to lock the stop sleeve in the halyard hook on the mast when I raise the main sail. I am getting the sail up all the way and I am pulling the halyard forward to clear the hook. I have tried this with the jib tensioned and not rigged at all. If I just try it without the main attached, it is no problem to catch the hook. So before I try anything else (like move the stop sleeve) I thought I would just check to see if anyone else has experienced this problem on their Hobie 16 and if so, how did they correct it. This mast does not have a comtip, whatever that is.
Will appreciate any advise you can give me.
