So while sailing in Richmond YC Multihull regatta we hit a seal in San Francisco Bay going about 20kts - both of us on the wire, the boat came to almost a complete stop in the water. After we got everything back onboard we pulled up the board and the front edge was clean, but we took a 2in chip out of the trailing edge.
Left the boat in the water that night to race the next day, came back in the AM and entire starboard hull was filled with water.
Turns out we put a 1in crack in the daggerboard trunk. The repair cost $1500 and we had to cut a hole on the inboard of the starboard hull and repair the trunk from the inside. Thanks to Craig at Elkhorn Composites the repair on the boat and board came out fantastic.
Moral of the story, break the board when at all possible, not the hull!
One thing to note if you are doing a repair on a MKII. There are bulkheads on the front and back of the dagger trunk, and there is another bulkhead that is midhull vertically and surronds the dagger trunk horizontally but is not attached to it. This is important to know if you are doing a repair as your access hole has to be BELOW this horiztonal bulkhead or you can't access the bottom of the trunk where it meets hull.
Edited by longboardebo on Oct 30, 2013 - 08:41 PM.
_____________________
Gary
2012 NACRA F-18 MKII
