Replacing Nacra 6 Tramp
Hi,
I just purchased a new tramp for my Nacra 6. I wonder if you can address me to a user manual guide or just give me instructions for how to remove the old tramp and replace it with the new one.
Eric
You have to drop the mast, remove the beam straps on one side of the front beam so you can lift the beam high enough to slide the tramp out
Dear Hullflyer,
Thanks for your reply.
Eric
There is also a bolt on the inside of the front beam. While you are at it pull all your strap bolts and clean them and lube with teff-gell. You will thank yourself someday.
Nacra 6.0na.Sail #111
Nacra 18 Square. Sail #1004
TNX
