What size (width) cat trax for Prindle 16?
Want to buy cat trax for Prindle 16... What size should I get?
Mike
1975 Prindle restoration project "Sanchah"
Retired Teacher
Newbie Sailor
Measure under the bottom from the outside edge of the hull to the other at the side stays. I think it is 8 feet ish, but you should measure to be sure before you buy anything.
You need the 8 foot axle without cradles.
http://www.floridasailcraft.com/CatProducts.htm
the tiger trax or cat trax. The black balloon tires work much better over uneven surfaces.
Hobie 16 in rebuild
2 Hobie 18 past
NACRA 5.2 past
Saint Cloud, Florida
member Lake Eustis Sail Club
OK... Have ordered 8ft Cat Trax... Next question... Can I use a bike lock to lock it to my trailer while I'm on the water?... Or is there some other system?... Thanks for info... icon_smile
Mike
Retired Teacher
Newbie Sailor
use a ss cable 8' in length with a small loop at each end. i run the cable under the front crossbar, thru the cutouts in the boards, and use a combination lock that is inserted thru a hole in the end of the axle and thru the 2 loops. i store the boat on a beach, you might need more length for the trailer. just measure.
Cool Curly, I just bought the same boat, Green hulls.
Cpl pix in the Albums.
Needed a refit & sever deoxidation treatment, ie. elbow grease
1975 P16 "Spring Rain"Sail # 642
Home Built 2004 Optimist-Delta "Unity"
So old it has Dino hide for a sail Chrysler "Pirateer"
Steve
Oyama BC
Lat 50.1167 N
Long 119.3667 W
1700 ft
