Hello all,
A friend and I recently purchased a surprisingly well cared for 1974 H16, considering its age. The sails are original with alternating white and yellow panels. The hulls are avocado colored and I've already repaired three soft spots without a problem. Our goal is to sail this boat for two years, and then run it into the ground with use after that. The problem I am encountering is with batten length. Due to the age of the sails, they are quite blown out leading to longer batten pockets due to stretching. The mainsail battens all have enough length to be tensioned well enough to sail. The jib battens are a different story.
Two of the jib battens are just a tad too short to tension well enough to ensure they seat in the end caps reliably. It's obvious that previous owners sailed with them loose, as I've had to repair some tear throughs in the pockets. Due to the age and purpose of the boat, we are quite willing to cheat and use cheap fixes as long as they function for two seasons reasonably well.
I am considering purchasing some fresh batten grommets and installing them 1.5" deeper into the pockets to allow for greater tensioning on the too-short battens. I would sew small square reinforcing patches at the new grommet positions prior to installing them. Do you think this might buy me a few seasons of fun with an old boat? Remember, we are avoiding the slow money drain that often occurs. We plan to pick up another boat in that same time-span, so our fixes aren't meant to be rock solid and everlasting.
If there are better tricks anyone has used or heard about, I'd love to learn!
