OK sailors, I will be asking lots of questions here and hopefully this community can save me from some common mistakes and direct me to links that solve my issues.
A little about my new boat. Bought off of Craigslist for $2K and haven't had her in the water yet. Hulls are solid and sails are crisp. Lines are pretty dirty and in rough shape. EPO rudders and original tramp. Trailer MUST be good since I drove it 4 hours back home to Bowling Green, KY.
Just placed my first order for some parts with Sunjammers in PCB, FL. I go to PCB a lot and thought I'd call that store my home base. Brad is helpful too!
Time to get my new baby looking good!
Question #1 - what is the best way to get the textured surface of the top of the hulls to shine? Pressure washing has removed the dirt and some of the chalky film, but now I want to scrub her clean and then protect with something.
Question #2 - The "black" on the mast and the cross beams is faded to grey. Is there a way to bring the black back?
Question #3 - This is for later, when the kitty is replenished, but the tramp is a 2 piece - not laced in the middle. When I replace it, should I go back with original or do a 3 piece that laces in the middle? Best place to buy?
Question #4 - Is it OK to wet sand the hulls to get the lake stain off - say 1000 grit?
Question #5 - The hulls are worn thru the gelcoat on the bottom - pretty will amid ships. How is this built back up?
Question #6 - I'd like to replace all of the faded/missing decals on the boat. Are there any sources other than the Hobie "bible". I found a couple for the mast, but there appear to have also been decals on the front crossbar.
Question #7 - There is a soft Velcro type material around the daggerboard slot that is breaking up. What do you guys do here to fix this.
Question #8 - I am planning to get my main sheet (7/16") and jib sheet (5/16") -both Sta Set, along with a replacement main halyard (5/32), from Mauri Pro. Any downside not going with Hobie parts here?
THANKS!
Tim Young
Kentucky
