The 570 uses a "blade" jib, I'm not sure if the self tacking is standard or an option. IIRC most of the 570's were also set up for a spin.
At this site you can see both manuals & go over each in detail
http://www.nacrasailing.c…download/nacradownloads/
Nacra Manuals will open up a sub menu where you will see the 570 & the 5.7 under "Vintage"
The older Nacra manuals are also here at The Beachcats, in albums, Technical, pg 5.
http://www.thebeachcats.c…ictures/?g2_itemId=35212Edited by Edchris177 on Apr 29, 2014 - 04:56 PM.
