Mast compatability
Does anyone know if a nacra 5.8 mast is interchangeable with a Prindle 18? Most importantly. is the shape the same so the base and top would fit? Pete
New Prindle 18-2 Owner
Former Prindle 18 Owner
Multiple Hobie 16s
Boylston Massachusetts
The mast bases are not compatible. Swapping the mast step on the beam may not be very difficult though.
Thanks. Just to be clear, the profiles of the two masts are different, so I cannot fit a Prindle base into a Nacra mast. If I were to swap masts, I would have to use different mast step and base.
Multiple Hobie 16s
The beam profile on the 5.8 is round, while the P18 is teardrop, so you won't be able to change out the "steps". I believe the mast profiles might be the same, if so you could swap the Prindle base to the Nacra mast.
Other things to consider is that you will have to cut the 5.8 mast down from the bottom to get the hound to the proper height, and you would have to swap out some hardware. as the 5.8 is boomless.
did you find a cheap mast Pete?
1975 P16 "Spring Rain"Sail # 642
Home Built 2004 Optimist-Delta "Unity"
So old it has Dino hide for a sail Chrysler "Pirateer"
Steve
Oyama BC
Lat 50.1167 N
Long 119.3667 W
1700 ft
I found a cheap boat, a nacra 5.8. I have not seen it yet, but worst case I would break it down for parts. I would love to have a spare mast for my Prindle. I would also love to rebuild it if it is salvageable. No jib, needs a new tramp and I do not know if it has daggerboards. I would pick it up just so other 5.8 owners could have another source for goodies for their boats. BTW, anyone ever build boards from scratch? I'm thinking I could do it with a baltic birch core bondo, cloth, and gelcoat.
I was hoping to get there today to look at it but the person has not gotten back to me.
With that said, we were double trapping on the Prindle yesterday, plus had another 70 lbs of weight in the form of a dog, and the boat/mast held up great. I'm guessing the couple little dents in my mast are not a problem.
BTW, I love that boat. So easy to control compared to my days on a hobie 16. And it moves fairly well too. I am going to have to flip it at some point, just to be sure my wife and I have the weight to right it. We are 290lbs wet, probably right on the border of having enough weight to do it.
Multiple Hobie 16s
very cool, it's still pretty chilly to get wet here, 45 degree water.
My boat is ready for the water, need dog bones, will likely make them from 1/4 inch stainless rod.
still messing with the trailer would like to teade the 8 inch wheels for 12s.
new fenders needed, adding a winch, forward rollers and side rollers.
I'm pretty sure it's a factory Prindle trailer.
Steve
Oyama BC
Lat 50.1167 N
Long 119.3667 W
1700 ft
kernunnos I'm pretty sure it's a factory Prindle trailer.
The trailer that came with any Prindle was determined by the dealer.
Prindle did not make or sell trailers.
Common trailers were Caulkin, E-Z Loader and Zieman, to name a few.
Instead of 12 inch wheels, I went with the larger eight tires; 18.5 inches across. They work nice.
45 degrees? So nothing is frozen; I don't see the problem :)
Multiple Hobie 16s
Quoteneed dog bones, will likely make them from 1/4 inch stainless rod.
Don't bother, it isn't worth the trouble.
Email Pete Begle,(has lots of ads in the classifieds) or Dan Berger, also here. I'm sure they have a bucket of them & could mail your a couple for reasonable cost.
The ither option is just make them from line.
Many sailors have gotten tired of the bones bangin them in the teeth when sitting on the hull, && made them from line. My N5.7 is converted. I don't have a photo online, do a search, I copied someone else s good idea.
If you can't find it, I'll email a photo.
Just slide a piece of plastic tubing over the line to keep the "Loop" open. It works as good as a steel bone & doesn't crack your teeth. I had a couple of the 3:1 systems, so I can adjust on the fly, it works really well.
Edited by Edchris177 on May 22, 2014 - 06:23 AM.
Kernunnos, Have light weight plastic fenders off a Trailex trailer & plenty of dogbones. Email me for a pic. Pete
Cool guys thanks, I was thinking 1/2 inch stainless ring for the bones.
The plastic fenders sound good. Will email you P.
I thought the trailer was Prindle, as I saw a couple boats on a similar trailer, no forward rollers
Edited by kernunnos on May 22, 2014 - 04:17 PM.
Steve
Oyama BC
Lat 50.1167 N
Long 119.3667 W
1700 ft
