Hi all,
I would like to install 6in inspection ports (deck plates) 9" or so in front of the forward cross bar on each hull (evenly inside the textured deck insert) on my Prindle 19. I would like to have access there for many reasons (repairs from inside, electrical wiring for permanent nav lights,...)
The holes would be cut inside the bonded deck insert that has the non-skid texture. At that point, the deck is 14.50" wide and the hole for the ports (Beckson) would be 6.625" in diameter.
Here are my questions:
Is this a high stressed area to be avoided? The tension on the forestay and shrouds, and compression under the mast is all in this area. On the other hand, The hulls are largest and tallest in this area and the hole is in the middle of the deck (stress is generally runs along the edges, the guwhales)
I can reinforce with alternating layers of mat and woven roving around this hole from the inside if ever that is required (probably not).
I am sure others have done this, because dry storage is hard to come by on a cat. I prefer asking because I would hate to have the front end of a hull break off because I did not do my homework prior to hack/moding my cat. I do like going out in the very rough weather, enough to bend the cross bar bolts which I am changing as well.
Many thanks in advance.
Paul, aka LePirateVert
(The Green Pirate, not to be taken mildly nor seriously, arrrrghhh)
Edited by lepiratevert on Jun 03, 2014 - 01:45 PM.
