problem with nacra450 center beam
I remove the front beam to chance the traboline and now i cant screw one of the bolts.Any ideas?Sorry for my poor english.Thank you.
Assuming were talking about one of the bolts holding the beam to the hull. Try it with an anti-seize lubricant but don't force it. If that doesn't not work, inspect the threads in the hull fitting. Sometimes they will gall up.
You may have a bit of corrosion on the threads, or one or two threads are chewed up. I would find someone with a tap & die. Run the bolt through the die, & the tap into the fitting in the hull.
Put some oil on for lube. Run it in straight for a few turns then back it out, repeat.
If it is a thread or two that got chewed up, this will fix it.
As Bacho said, don't try to force it, you will just end up chewing up all the threads, creating a bigger headache.
Don't forget to put some grease on all the bolts when you re-assemble.
Edited by Edchris177 on Jun 10, 2014 - 09:09 AM.
