I noticed the little delrin fittings that connect the rudder arms to the cross tie bar on my 6XL are pretty cracked. In fact one broke yesterday.
They look like 1" rod, (OD) turned to 3/4" at one end to fit inside the cross tie bar. I'm sure they would be cheap & easy to make a dozen of them, if I had the rod.
As a ghetto fix I cut a piece out of the sidewall of a car tire, folded it in half & stuffed it into the X tie tube. Drilled a hole for the retaining pin, & another hole to accept the pin on the rudder arm. Put it together & trimmed the end.
It works, but it looks like, well, a piece of car tire stuffed in the tube.
Anybody have better solutions?
McMaster Carr has the tube stock, but they don't like to ship it Canada.
