Trailer Rack Project
Here is a simple trailer rack project that I thought I would share.
http://utahsummersailing.…r-beach-cat-trailer.html
Nice! Can't tell exactly how you attached it to the trailer.
lol i even took pics of every step for this project, then lost them. If you enlarge the picture of the rack (click on it) then you can see how the two pieces of the rack kit attaches to the 2x2 square tube. I simple removed the square tube and attached it to the trailer tongue instead.
nice job
1975 P16 "Spring Rain"Sail # 642
Home Built 2004 Optimist-Delta "Unity"
So old it has Dino hide for a sail Chrysler "Pirateer"
Steve
Oyama BC
Lat 50.1167 N
Long 119.3667 W
1700 ft
Clean install. Great idea. Thanks for sharing.
To Clarify:
HF rack has two halves that are bolted together.
At top, halves connect with two brackets at top rail line.
At bottom, halves connect to 2"x2" hitch receiver tube with 4 bolts.
To install on trailer:
Remove hitch receiver tube for rack.
Drill (4) bolt holes horizontally through tongue of trailer.
Bolt rack to trailer.
