I had sailed catamaran before but it was 25 years ago. My wife has also experience sailing with a laser.
We bougth the Inter 18 last fall because our child’s are old enough now. The girl is 15 and the boy is 12. We sailed the boat twice before Tuesday in light wind, under 10 mph on lake Champlain, VT. Water temp was about 75 F. Tuesday, back to lake Champlain, the wind was stronger, about 12 mph in the morning. Before going, we laid the boat on its side and I made sure I was able to right it by myself and it was positive. Good news, I would be able to sail it alone. So we sailed the whole morning and everything went fine. We stopped for lunch. After lunch we went back. At some point the wind grew stronger and my wife went out on the trap. All was fine until we pitchpole. First thing, I checked every one was okay. We went on the windward side of the boat and when I looked at it, the wind was pushing it away on its side. I swim to reach it and grab a rope that was trailing in the water. My wife stayed with the kids. I pulled myself to the boat and had a look to my family and saw that the distance between us was growing. I climbed on the boat, released the main sail and the jib, stand near the transom to rotate the boat at a proper angle to be righted. I righted it with no problem. That’s when things get worse.
I had installed a rope at the front to help climbing on board. I took the idea in this forum. I have made it pretty much the same way but a little bit different. It’s a rope tied to the front beam on each side with another rope tied at the middle that prevent it from going under the tramp when you push on it with your foot. I test the setup to adjust the length of rope but never push as hard as when you try to climb.
When I tried to climb, my foot pushed on the transverse rope and the knot of the retaining rope slide to the end, annihiling its purpose. I should have made it exactly like Catmodding has done his. 25 years ago I was 40 pounds lighter and 25 years younger. I was able to jump on the tramp using only my arms. Now I know I can’t do that anymore. It took me about 30 minutes to climb onboard. Once there, exhausted, I can’t see my family anymore. The waves were about 1.5 foot high. I searched them and after 20 minutes I stopped a motorboat and ask them to help me. We search for 1.5 hours before the motorboat found them. All were okay. They brought them to the shore. My boy suffered from mild hypothermia but the others fine. He has no fat to keep him warm.
Hopefully, that lesson on safety ended well.
1- We will modify or replace our climbing aid;
2- Every member will have a device to show its position and they will learn to use it. I still have to decide which device is the best;
3- Every member will have a whistle;
4- At least the boy will wear its wet suit.
Any other suggestions are welcome.
Edited by coolhead on Jul 03, 2014 - 05:12 PM.
AB
