So, after buying a well-used P16 last fall and blundering into a complete trailer rebuild, I finally put it in the water this July 4th weekend. Good news first - it did not sink! Bad news next - the tiller assembly fell apart and we had to limp to shore using the end of the main halyard line in place of a bolt that fell out and separated the left - pardon, port - rudder from the tiller crossbar. So,
FIRST LESSON LEARNED - make sure your tiller assembly bolts are properly tightened ensuring that the lock nuts are firmly engaged. ASIDE COMMENTARY - why are bolts used in an assembly that constantly rotates and is quite likely to unscrew the nuts, nylon locks or not? Wouldn't clevis pins be better?
SECOND LESSON LEARNED: if one of your rudders - say, the port one - does not properly lock, DO NOT GO SAILING without fixing this problem! I cannot emphasize this enough - you might think gravity would keep it down but apparently those locking mechanisms are there for a reason and not because Prindle likes fancy mechanisms. Evidently the water WILL pull the ruder back as the boat picks up speed, and that will make the tiller effort required so high that you will have to forgo the hiking stick and control the tiller by grabbing the cross bar.
THIRD LESSON LEARNED: before raising the mast, make sure your main and jib halyard lines are not tangled - it is difficult to impossible to untangle them once the mast is up.
FOURTH LESSON LEARNED: if your main and jib halyard are tangled up once the mast is up and you can't raise the main sail, it might be tempting to decide that since you're just learning you can go ahead and sail without the jib. DON'T! Drop the mast, untangle the halyards, raise the mast again and go out with two sails. This boat DOES NOT want to tack without the jib! Especially if your rudders are not 100% - see SECOND LESSON LEARNED above.
But aside from having very hard time steering, having to rig a rope replacement for a bolt, missing a jib and not properly downhauling (or, at first, properly hoisting) the main sail, and blundering into the high traffic narrow channel out of which I had to be towed - it was a BLAST! I can't wait to do it again with working tiller and a full and properly hoisted complement of sails - this boat is a ton of fun if you get it to actually catch wind!
Mike
Prindle 16
Rochester, NY
