Wings for Newer Cats
Help!!
There is someone here form SoCal that is working on a set of wings... I believe for Nacra 5.5 SL. Could someone put me in touch with them....
I have another gent working on a similar project and I think to two of you can help each pother out...
Shoot me a PM
Edited by JohnES on Sep 12, 2014 - 07:57 PM.
John Schwartz
Ventura, CA
John,
That would be me. I have built a set for my Nacra's and have mounted the first on my Nacra 5.7. The design will work on any CAT with 4" round cross beams that don't have the traveler track extending over the hull portion of the beam. I have to work on mounts for other shapes but don't think it will be a problem.
The first real production prototype worked out well on our trip to Tahoe and the most recent trip to Mission Bay. All my non sailors commented on how much better sailing on the CAT was with them since they didn't have to sit on the tramp and try to stay out of the way off all the sheets. I actually enjoyed using them quite a bit too. They are incredibly easy to remove or fold up for trailer'n, but I never ended up removing, and was able to fly the hulls quite high with out issue.
I plan to build and sell these, but my main business of manufacturing cartridges and systems to take oil out of water has been booming as of late and left little time for focusing on something new. I've kind of resigned myself to the fact that this will end up being a winter project with the plan to make available for next season. I would like to get my hands on some of the newer CATS with the 'D' beams so I can design the mounts for those.
Craig
Windrider Rave Hydrofoil
Nacra 5.8NA
SoCal
Check your PM... I can get ya some one with the D-Beam
John Schwartz
Ventura, CA
John, I hadn't talked to Brett Johnson (azcat) after the Tripoint race, so emailed him. " I beat Lee (Wickland) by welding a whole bunch of extra aluminum to his boat". Pete
pbegleJohn, I hadn't talked to Brett Johnson (azcat) after the Tripoint race, so emailed him. " I beat Lee (Wickland) by welding a whole bunch of extra aluminum to his boat". Pete
Trying to put thee two in touch.... maybe he can help Lee refine what he is doing....
John Schwartz
Ventura, CA
nacraflyerJohn, I have a n
Nacra 6.0 and a set of wings from my old Prindle 18.they came from
Murrays in the late 90s.they had rubber beam inserts to mount the wings
cant find the ones for Nacra,any ideas would be helpful
David
David,
The seats that I'm building don't fit inside the beams like those you have. But you should be able to make a mold and cast some fittings, or even better, get some PVC or Delrin stock that is 4" OD and have a machine shop turn down, notch for the bolt rope area in the beam, then drill a hole down the middle to receive your current seats.
Craig
Nacra 5.8NA
SoCal
