NACRA 5.5 uni - project boat, main beam damage
Hi all,
Glad to join the forum and learn from all the experience here. I recently acquired a Nacra 5.5 uni (not assembled) in very good shape, except for some major damage to the main beam. There is a jagged hole torn through the dolphin striker rod area. I don't know whether to repair, replace, or manufacture my own new main beam from blank marine aluminum tubing.
http://s25.postimg.org/p3jgwd36n/IMG_5453.jpg
http://s25.postimg.org/lmm074ti7/IMG_5446.jpg
The full story is here: http://www.catsailor.com/…Number=275533#Post275533
Thanks for your thoughts! I'll have many more questions to do with setting up and tweaking the boat once the hulls are together.
Cheers,
Hobie Getaway, Nacra 5.5, Hobie Tiger
Wish list: A-cat classic, F16 Viper!
Northern California
check out a local welding shop first, they may be able to cut out damage and put a patch in. if you make a new beam, i'd probably use 6061-t6 tube, 1/8" wall. i have a friend who made one piece beams for an sc20 and no problems with them.
Mike Conway
Hilton, NY
I wouldn't bother trying to save it. That damage is too bad and they aren't hard to get. Measure it and Fire Pete begle and dan Berger on here a private message and see if they have one available. Someone else, like Chris Hilliard, may also have a spare.
It looks like New England catamarans also has some for sale.
Thanks Dave, I'll follow up those leads, much appreciated.
WolfmanI wouldn't bother trying to save it. That damage is too bad and they aren't hard to get. Measure it and Fire Pete begle and dan Berger on here a private message and see if they have one available. Someone else, like Chris Hilliard, may also have a spare.
Northern California
I saw Wolfmans reply, I have a couple of beams, at least 1 V strap, & a couple of the pads that fit on the V strap.
Measure your beam length, DS rod length, & the distance between the holes that the V strap bolts to. Measure from the inside hole across the beam to the inside hole on the other side. Nacra used a bunch of different V straps.
You need a new DS rod, I only have 1 spare & am keeping for when disaster strikes. See my album in the Tech help section for building a new one for cheap. Make sure you install BOTH washers. The rod should be 9/16". You do not need that hole in the V strap, the square pad sits on the strap, held by something like Dow 5200, & the pressure from the DS rod. The rod sits in a hole in the pad. the last photo shows both washers, beam preload, & the pad.
http://www.thebeachcats.c…pictures?g2_itemId=73301
All the holes on the bottom of your rear beam are to give access to the nuts securing the traveller track, they are just big enough to slide a thin socket into. If you undo them, use nylock(aircraft lock nuts & or a drop of BLUE Loctite to re-assemble.
I'm in Canada, if you are in a hurry Dan Berger & Pete B would be able to ship cheaper. They are both trustworthy people. Otherwise I can send it next time I'm in the US.
I would get a used beam, they are not expensive.
One thing that looks different is the front beam tramp groove. It appears yours is riveted onto the beam?
All the beams I have seen have a groove integral with the extrusion. Looks like this; (Image from Bill)
http://www.thebeachcats.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=106889&g2_serialNumber=2
If funds are scary tight, use the old rear beam, you're not racing in the Nationals. I sailed an N5.7 for two years with a definite "ripple" in the front beam. Drill bigger rivets,(IIRC 3/16" is about the biggest that the cheapo hand riveters will pull), or use an aluminum washer, as backing, with the same size rivets. If you use washers make a tool from a piece of tubing or broomstick, with a hole just smaller than the washer close to the end. Put a piece of masking tape over the hole, then stick the washer to it. Start with the rivet closest to the centre of the beam, if you start at an end, they will be in the way as you try to work inwards. Place a nail into a hole, have a helper push the broomstick in from one end til you hit the nail. Remove nail, & manoeuvre the last 1/4" to line the washer up with the hole. For the rivets in the centre, it will be easier to also slide a second wedge shaped stick in from the other end. This will serve to push the first stick upwards against the hull, & hold the washer snugly while you install the rivet. Push the rivet into the washer,through the masking tape, pull it...repeat til done.
The hulls look like they are Cal-I-forn-I-A registered, I assume you're close? Pete B is in Big Bear.
Post any other queries, there are a few 5.5 sailors here.
Edited by Edchris177 on Sep 22, 2014 - 06:54 PM.
Edchris177, thanks so much for your detailed reply - so much useful information there. How to I get in touch with Pete B and Dan Berger? If I can find replacement beam/s in good condition (I only want to do this once) at the same or significantly less cost than making my own new ones, I would consider grabbing them. After hearing all the advice, there is a certain appeal in making my own new beams from blank tube - but my wallet will decide ultimately. I promised my wife this project wouldn't get too expensive!
I think getting a machine shop to make me a DS rod is a good option. Your step by step albums are very helpful. With the v-strap, I will take the less expensive option between getting a shop to weld a little reinforcement on the underside of the centre hole, or buying a whole strap second hand. I'm curious to remove the pair of bolts on each side holding the strap to the beam, to see if there is as more bad corrosion hiding. That might make the decision for me.
Would you mind sending me a p.m. with how much you are asking for beam/s, ds support casting/pad, and v-strap? Thanks. I've been away from home a few weeks, but I'll try and measure things soon when I get back.
My tramp groove is indeed riveted to the beam, and not extruded as shown in your pic. Is this uncommon? Also perplexing, every Nacra thread I've read shows/describes the the anti-rotation in the beam coming from a bolt that threads through the internal beam casting 'half-moon' and into a hole in the hull. My boat has a threaded stud protruding FROM the hull, in each beam cradle. I assume I just need a lock nut on each stud, on the inside of the beam, for the same result, along with two of the internal beam casting 'half-moons' from Murrays. http://www.murrays.com/56-2511.html I can tell I'm going to spend a lot with them after I also get the mast ball and compression tube, and no doubt a few other bits and pieces.
I'm not far from Tahoe CA, a little north.
One last thing - how do I make a photo album? I wouldn't mind posting a whole bunch of pics of all the pieces I have for the boat, so anyone interested can comment on anything good/bad/weird that they notice. As I say, my understanding is the hulls do not belong with everything else I have, so there may be some mismatch.
Edited by sierracat on Sep 27, 2014 - 07:51 PM.
Northern California
QuoteOne last thing - how do I make a photo album?
Click on the tab at the top of page SITE FAQ, Damon has a tutorial there.
P Begle is usually on here, just look through some of the posts & PM him. I think you could also find Dan Berger by a search. I think if you go into your PM box, you can search out a member.
If trying to keep a shoestring budget, probably Pete or Dan can get you the beams cheaper, as shipping would be quite a bit less. If they are over 8', price goes up. I don't think I have any extra 1/2 moon chocks, try to get them used, some of those parts are pretty expensive new, & they don't really wear out.
Do you have the manuals for Nacra? Here is the link.
http://www.thebeachcats.c…pictures?g2_itemId=35212
I don't have personal experience with the 5.5, but I have never seen a Nacra with the tramp channel riveted to the front beam, nor have I seen "studs" in the hulls. What year is the boat?
Are all the bolts these studs, or is it possible they used to be bolts & the heads were twisted off?
I think I have an old mast ball, it's pretty worn, but I'll give it to you to get on the water.
PS don't buy the Parts Catalog, I can email you one, I don't think Damon has it cached here.
Edited by Edchris177 on Sep 27, 2014 - 08:42 PM.
http://s25.postimg.org/s55r3nfxb/IMG_5444.jpg
Not sure what year it is. I've heard that the serial numbers are on the starboard transom, but I couldn't see one anywhere. There's just one bolt stud per side - to stop the beam twisting. It still has the normal holes for the beam straps (4 per hull).
Northern California
This thread may help with finding an HIN #
http://www.thebeachcats.c…nc=viewtopic&topic=14494
It turns out a number of the Nacras did use the studs you show.
Do a search for Richard Obren,(maybe Obrian?) in members, I think you access it from your PM box. He used to post a fair bit & has a 5.5 Uni.
Thanks Edchris177, and I got your PM, I'll be in touch.
I'm starting to realize my current beams don't add up. I think perhaps they didn't come from/with these hulls, even if the intention was for them to fit when they were rebuilt. They are 8ft 5in long (is this spec for the 5.5?) and 4" OD, and appear to be 3/16 in thick. The front beam has the tramp track riveted on, as people have pointed out isn't normal. The studs coming out of the hull need corresponding holes in the beams. As I said, the rear beam has holes that don't line up in a way that makes sense, and the front beam it turns out doesn't have holes at all! The beams have a lot of weird holes and stains from previous fittings, as if they were set up on a different boat. The Nacra manual shows the traveller track running the full length of the rear beam. Mine has a stain in the beam where it looks like one used to run full length, but now finishes short, on the inside of each hull. I've learned earlier Nacras may have had these short bolt-on travelers, and later boats had a full length traveller that was extruded. More postings as I unravel the mysteries.
Edited by sierracat on Oct 01, 2014 - 09:12 AM.
Northern California
I have a 5.5 Uni and can take as many pix as you need. It appears you have a hodge podge of parts. Call me if you want 816 436 161 zero.
Lake Perry KS
H-18
N-5.5 UNI +spin
Hey, thanks Ricard! I'll definitely be in touch once things start happening with putting it together or fabricating parts. Much appreciated. You could start by sending me a couple of snaps of your trailer, and the way the boat is supported on it? I picked up a light boat trailer I need to modify for my 5.5.
Thanks.
RicardObenI have a 5.5 Uni and can take as many pix as you need. It appears you have a hodge podge of parts. Call me if you want 816 436 161 zero.
Northern California
Email me. Richard at Northracecars.com
Lake Perry KS
H-18
N-5.5 UNI +spin
Update: not a lot of used beams around. Looking at the blank tubing route. I can't measure wall thickness accurately, but it's a little more than 0.0625, and one source I have suggests 0.078 (5/64t) which apparently is an odd size. Thinking about going up to the common 0.125 (1/8in) and filing down the compression tube a hair to fit. Waiting on a quote for a stick of this stuff (4in OD) and I'm sure I'll almost fall over when I hear it.
Dolphin striker rod: trying to get around the $70 buying a new one, but custom making one mite be too expensive (I don't know any hobbyist machinists). Apparently 9/16th is an odd size for stainless rod, on top of the fine (18) thread. Damn sailboats!
V-strap: looking at either welding a brace over the corrosion at the centre of the V (isolating potential cracking and the mysterious drilled hole) while also acting as a dolphin striker rod casting. Or ordering the flat bar and bending a new one. Talking to a shop to figure out what alloy it is. He thinks 7 series (bendable, not very weld able) so may not be able to fix old one.
Oh, and to top of the weird sizing of all the materials (apparently this is deliberate by many manufacturers so that people have to buy original parts, not make them like I am) the trailer steel (channel) is an odd size, so I can't match it easily. Not that I care to much about that, since I'm not trying to fit anything to the old frame, just adding across the top of it.
Northern California
I don't belive the 5.5 sl or uni ever had the bridle tangs on the outside of the hull. You may have an old 18 square that has been cut down in width. They had the tangs on the outside.
nacra55I don't belive the 5.5 sl or uni ever had the bridle tangs on the outside of the hull. You may have an old 18 square that has been cut down in width. They had the tangs on the outside.
How do you mean? Without a jib, the uni doesn't have a single forestay and a bridle foil, it has twin front stays and then the aft pair (not sure if my terminology is correct). Are you saying the two chain plates on the outsides of each hull should be on the inside? That doesn't seem right. Thanks for your observations though, I'd like to understand better.
Northern California
I think the uni rigged boats had tangs on the outside.
http://www.thebeachcats.c…nc=viewtopic&topic=11472
"for a uni rigged boat, like the 18m2, the best position for the bridal tang is on the outside of the hull, but for a jib equipped cat the bridal tangs need to be on the inside of the hull"
Northern California
Album of the boat parts here: http://thebeachcats.com/pictures?g2_itemId=111519
Northern California
Added some more pics to the album. More detail on tramp type/condition, traveller, wire rigging, trapeze, pivmatic, etc. http://www.thebeachcats.c…ictures?g2_itemId=111519
Northern California
I looked through your album, & I know funds are tight;
Trap sheaves, don't worry about them. I have had several sheaves break, but the pin will stay. You can still use them, without the sheave til you change wires.
Same thing for the traveler sheave, if it breaks the pin will hold the line. It looks like an old Kenyon, I had the same thing on an old 5.2, it had "Kenyon" stamped on it. Don't put any lube on it. If you can find sheaves that fit, change them. Just be careful removing car from track. The wheels are sitting loose on short studs, they will fall off & spill TINY bearing everywhere.
Use a small block of closed cell foam,(something smooth...I stole a bit off the wifes yoga mat), make it wide enough so you have to squeeze it a bit to make it the width of track.
Squeeze & slide car onto foam block, then wrap some tape to keep it there, reverse to install. Do I need to remind you NOT to let those wheels fall off!
Use your traveler cleat,it looks serviceable, once the teeth get worn, they won't hold. They are easy to change, I have a bunch of them. You don't need the whole thing, just the jaws, they disassemble easy. Use blue Loctite to assemble, you don't want that small bolt coming loose.
The tramp looks pretty beat, but is probably serviceable, I would have it completely restitched with good UV thread.
The fitting on the front beam looks like a gudgeon for a rudder pin, same as on your transoms, don't know what they added it for.
When you rig your rudders, use the bolt holding tie bar to tiller to hole your bungee, it's easier than figuring out how much extra to stretch it to make up for the distance it slides back down the tube to the pivmatic pin.
Mast rotator- you might want to forget about it til you get used to the boat. It has to be released every tack, & if you forget, you can break the mast...there is a note somewhere in the manual about that. See my old Nacra 5.7 album for how to rig it.
DON'T leave your diamond wires as is. If those arms slide up or down on the wire, you lose the integrity of the truss, & all the strength. You can use rigging tape,(the bit of seizing wire the manual calls for is not great), but the cheap fix is a roll of electrical tape. Get coloured tape,(the black leaves icky residue) then tightly wrap it in a figure "8", above & below the spreader bar. That will prevent any movement of th e spreader on the diamond wire.
If you don't have those little plastic donuts on the diamonds, just above the spreader, add some. They keep the jib from wearing as it rubs on the bars. You can buy a set that clip on if they are missing, this is what I put on the 5.0.(I used the smaller size, for 3/32" wire IIRC...they were $18)
http://www.westmarine.com…par--jib-rollers--111864
QuoteUse a small block of closed cell foam,(something smooth...I stole a bit off the wifes yoga mat),
I told my wife this, and she gave me a dirty look. icon_wink I don't think I'll have to remove the car. I just duct taped it on to the track before I removed the track.
So the big news/update is: I took a deep breath and a fresh beer, and went to work drilling out all the old rivets to remove the fittings from the old beams. I was expecting to go slow, use lots of cutting oil, and probably wreck a few drill bits on the many stainless steel or Monel rivets. BUT, the first rivet drilled like butter… what the??? And I quickly realized EVERY SINGLE RIVET on the old beams were aluminum. Unbelievable. No wonder every fitting was loose and wobbly. But no matter, someone else's crappy work meant I was drilling out each rivet in 4 or 5 seconds. I am just hoping that the rivets on all the mast fittings are not aluminum too - this would be a disaster waiting to happen. Aluminum just isn't appropriate for high stress fittings on a boat. I shall investigate and replace them all if necessary.
Not only that, but I found things like the traveller cleat rotator plate was riveted with looooooong aluminum icon_eek rivets that didn't make it all the way through the casting so they could pull/mushroom properly. Essentially just a little friction from a very soft metal in the sidewalls of the hole. Oh dear. I can't believe half their fittings didn't rip off the boat.
The old beams are now stripped, and the new beam tube is cut to length and ready for assembly. I'm experimenting on a piece of beam tube off cut with x-fine grit wet/dry sandpaper. Since I'm not gutting anodizing done, the new beam tubing is quite shiny, and I want to dull it down a bit so it doesn't look odd, or show up scuffs and scratches too easily.
Questions: Should I through-bolt the traveller cleat on to the casting, rather than try to rivet? (It really looks to thick to rivet, as the previous owner must have found out).
Also, do I have any options attaching my old traveller track to my new beam, besides drilling a bunch of huge holes to fit a socket through to nuts on each screw?
http://www.thebeachcats.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=112323&g2_serialNumber=3
What the hell were they thinking?!
http://www.thebeachcats.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=112320&g2_serialNumber=3
Swiss cheese!
http://www.thebeachcats.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=112321&g2_serialNumber=3
Like butter icon_cool
http://www.thebeachcats.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=112324&g2_serialNumber=3
Edited by sierracat on Nov 29, 2014 - 11:50 PM.
Northern California
QuoteIf you don't have those little plastic donuts on the diamonds, just above the spreader, add some. They keep the jib from wearing as it rubs on the bars.
This is a uni rigged 5.5
Thanks for all the other tips. Will wait and see which sheaves/cleats decide to explode in the first big wind. Will install the rotator cleats but not use it unless needed one day.
I thought my tramp was serviceable, but went outside the other day for a proper look and the stitching is toast - it can all be ripped apart by hand. I think the fabric itself might hold up, so I'm taking it to a local upholstery place to get restitched (I'll ask if they have UV thread for UV resistant thread). In the meantime I'll be daydreaming about a brand new electric blue tramp from SLO sails some day…
http://www.slosailandcanvas.com/media/00/a20792b127b140c0431b1e_m.jpg
Northern California
Quote Should I through-bolt the traveller cleat on to the casting, rather than try to rivet?
I've got several of them, from old 5.2's, I think they are all riveted. I think it was just aluminum rivets to hold the casting to the rear beam, I remember they drilled off easy. The bullseye used machine crews to secure it to the fitting. SS bolts would be easy, but you have to make sure the bolt heads don't interfere with the swivel mechanism, IIRC there is not much clearance. I', going up to the lakehouse tomorrow, I'll see what's in the bin, I might be able to send you an entire package.
Quotethe new beam tubing is quite shiny
It will loose much of that shine quickly, with exposure to the elements.
Quotedo I have any options attaching my old traveller track to my new beam,
Myself, I would suck it up & start drilling. Those old tracks are fairly high profile, the rivets would need to be close to 1" long. I think you also need countersunk heads that will end up flush with the track.
There is quite a bit of stress on the track, though it is spread out over a bunch of fittings. If you did go aluminum rivets, I think a backing washer would be in order. You will need to keep everything in alignment. I would fit the track, then wrap tape to keep it in place, then mark or drill pilot holes, from the track through to bottom of beam. Then drill out the bottom holes, that way everything will line up. The machine screws will be pretty small diameter, you can use a 1/4" drive, or even a nut driver handle with small socket, so the final holes won't be that large. Support the beam rightside up, so you can install nuts/lockwashers(or use blue Loctite) from the bottom, that way they won't fall off...it will be a 15 minute job. Just stick a bit of gum/plasticine etc into the socket so it holds the nut/washer just flush with socket edge.
You will probably need fasteners with countersunk heads, I can't remember how much clearance there is from track to car on those old setups.
Quoteso I'm taking it to a local upholstery place to get restitched
If they only do upholstery, it might not be a good choice. Someone who does awnings/biminis etc will understand what you are doing, the stresses on the tramp & have proper thread. A chap here who used to own a boat & awning business redid our entire 5.0 tramp for $40. Expect to pay more if they use Technora(sp?) thread.
QuoteI thought my tramp was serviceable, but went outside the other day for a proper look and the stitching is toast - it can all be ripped apart by hand. I think the fabric itself might hold up, so I'm taking it to a local upholstery place to get restitched (I'll ask if they have UV thread for UV resistant thread).
I had picked up a H16 a few years that had a tramp like yours with the stiching routed and the fabric still in good condition. I took mine to the local sail loft and they did a great job of restiching the whole thing and installing new hicking straps $60. it's still in great shape.
Jeff O
N5.0
solcat 18(sold),
N5.2,
Camarillo CA
QuoteIf they only do upholstery, it might not be a good choice. Someone who does awnings/biminis etc will understand what you are doing, the stresses on the tramp & have proper thread. A chap here who used to own a boat & awning business redid our entire 5.0 tramp for $40. Expect to pay more if they use Technora(sp?) thread.
Quote took mine to the local sail loft and they did a great job of restiching the whole thing and installing new hicking straps $60.
No sail shops anywhere near me. I'm sure my local shop can handle it. They do boat covers and awnings etc.
Quote I', going up to the lakehouse tomorrow, I'll see what's in the bin, I might be able to send you an entire package.
Thanks, very kind of you.
QuoteI think it was just aluminum rivets to hold the casting to the rear beam, I remember they drilled off easy
In my opinion, every rivet should be stainless or monel, unless through a very light duty fitting. Can't speak for what you've come across. I will be using all stainless 3/16 rivets on all my fittings. I've used aluminum for other non boat projects - they are very soft and weak.
QuoteMyself, I would suck it up & start drilling. Those old tracks are fairly high profile, the rivets would need to be close to 1" long. I think you also need countersunk heads that will end up flush with the track.
No issues with time spent drilling - the 6061 cuts like butter with a good bit, especially step drills for the large access holes needed for a socket head. (Step drill bits are AWESOME!) I just keep pondering the sag in the old beam, and the amount of material taken out from the underside of the rear beam with all those 1/2-3/4in access holes. Structurally, I don't like it. Swiss cheese. But if that's the standard way, so be it. My beam tube is 50% thicker (0.125") so I shouldn't be concerned. They probably had some sort of accident to put the bow in the old rear beam anyway. I keep hearing rumors of previous owner's run-in with heavy snow pack one year, so that could explain a lot of things.
I will be using all the old SS countersunk machine screws/nuts that came with the old traveller track. Loctite is a good idea - I'll pick some up.
Northern California
BTW, I have a method of lining up through-holes on large diameter tube like a beam. Take a punch and make a dot. Get a flexible flat tape, and measure the circumference around and back to the dot. Divide that number by two, and measure that amount and make a another dot (e.g. 9in circumference, make a dot at 4.5). Drill each dot independently. Done - no need for a drill press. Did I mention how awesome step drill bits are? They also slightly
self-bevel the rough edges of the hole.
http://www.thebeachcats.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=112335&g2_serialNumber=3
Edited by sierracat on Nov 30, 2014 - 10:40 AM.
Northern California
Quoteand the amount of material taken out from the underside of the rear beam with all those 1/2-3/4in access holes. Structurally, I don't like it. Swiss cheese.
It isn't a problem, all the Nacra's were built that way,& I've never heard of beam failure. Think about aircraft construction, the webs in a wing are so full of holes there is more hole than material. It's all about where the holes are in relation to the load.
If the holes were in the side, it would weaken the beam. If the beam is subject to vertical bending loads, the bottom is either being compressed or pulled apart. Either way the remaining material is stronger than the rest of the boat.
Quote Loctite is a good idea - I'll pick some up.
Be sure to use blue, red is for more permanent fittings, though it can be undone with the application of heat..
Tom,
It looks like your boat is going to be better than ever, glad you are able to get it all figured out.
How To Create Your Signature
DamonLinkousTom,
Yes, it's coming along nicely, thanks! I appreciate your positivity. Almost done building the main beam from all raw materials, and then the rear should be even easier (less calculating anyway). I plan to start a new thread documenting the methods and tips for beam rebuilding, and generally compiling all the obscure information I've found out about early Nacras from different sources. Some of the info I've gained has been from these forums (I'll copy the links to my various threads with Q and A in the new rebuild documenting thread) but also there's some nifty facts I've found out that I couldn't find on the internet anywhere for the life of me. Hopefully the next person with an old Nacra project can get 90% of the information they need from one place.
One interesting fact I learned (from Nacra): Mast post/v-strap/beam assemblies are not mounted vertical relative to the top deck of the boat. They are angled a small amount aft (ball leaned aft, bottom of rod forward), perhaps 10Âş or less. Makes sense with mast rake.
OK, back to the shop for more tinkering.
Edited by sierracat on Dec 01, 2014 - 01:52 PM.
Northern California
Quote They are angled a small amount aft (ball leaned aft, bottom of rod forward), perhaps 10Âş or less. Makes sense with mast rake.
Yes, the entire idea behind the V-strap is to create an engineered truss, much stronger than a 4" beam could supply. The load still tries to bend the truss,(creating tension on the bottom of the tube & V-strap & compression on the beam top), but the strength now approaches that of using a beam with a diameter equal to the length of the DS rod. A 14" beam would achieve the required strength, but would be difficult to mate with the hulls, & probably weigh more than the truss.
The Mast ball serves as a means to connect the mast to the truss & transfer the vertical loads to the DS rod, & thereby to the truss.
The truss is strongest when the load is vertically through the DS rod, & weakens as the loads move away from vertical. The extreme would be a horizontal load,(mast falling), failure would occur at the load required to bend the DS, or tear the hull fittings/straps loose.
Edited by Edchris177 on Dec 01, 2014 - 03:29 PM.
I have not forgot about the dimensions you asked for but the boat is in the barn not here and I have to pick a day to go dig it out and get the measurements you wanted. Nice work so far. Richard.
Lake Perry KS
H-18
N-5.5 UNI +spin
RicardObenI have not forgot about the dimensions you asked for but the boat is in the barn not here and I have to pick a day to go dig it out and get the measurements you wanted. Nice work so far. Richard.
Hi Richard, no worries, and thanks for checking in. I won't make you go to the trouble anymore as I've blasted ahead and built the new beams and assembled the boat. Everything seems to be lining up so far.
Northern California
I've been busy! I built my new beams, and assembled the hulls, along with finishing the trailer. No tramp installed yet, and need to overhaul the rudder assemblies. First test today putting the mast and sail up, checking the stays were the right length and all my calculations add up (they did!). Very exciting to see it come this far!
One concern - with the sail up I noticed the old adhesive outline of a removed sail marking that reads '18s' (as in 18 square). You may be able to just make it out in the photo, below the Nacra logo and the red 5.5 numbers. So my 5.5 uni, made up of 18sq hulls, with previously chopped down 18sq beams, may now also have an 18sq sail?! I guess I don't really care what we should be calling it, but I would like to know if it truly is an 18sq sail, and if so, how that might affect the boat on the water. Bigger sail area comes to mind, with added power, but not sure if this will change the handling adversely (besides the extra healing moment). The mast is 29'6" long (excluding casting) and the sail seems to fit it well. I know early 18sq had a boom, then they went to boomless. This sail almost looks like it was made for a boom. Perhaps the silver colored clew plate could have been added later?. Even hooking my mainsheet to the most inboard hole of the clew plate, sheet tension isn't pulling outboard enough, and the foot of the sail won't tension properly. On the most outboard hole it looks just ridiculous - the foot of the sail has a giant flapping belly in it. I know the rear beam/traveller is meant to angle slightly forward on boom less, and slightly aft on boom rigs, but I don't think that will matter the way things stand. Any thoughts appreciated. 5.5 uni boomless sail, or 18sq boom/boomless sail? Issues?
http://www.thebeachcats.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=112746&g2_serialNumber=4
http://www.thebeachcats.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=112749&g2_serialNumber=4
Northern California
I really know nothing about boomless rig but the rear beam look too much forward if we compare it to the 5.5SL in the classified.
Maybe the angle of the shot make it look like that.
AB
Well it is certainly not a 1990s style boomless 5.5 sail, those had a 'boomlet and a distinct triangle and flat part. From what I can see, it does appear to be an 18 sq sail that a hefty 'boomlet' plate has been attached to. The good news is that the sail does have a distinct downward triangle below the lowest batton, the same as the boomless sails. I think the 18 sq sails were made that way, or the previous owner (or even the factory) may have modified it for boomless. So the boomless rig should tension correctly. So that sail will likely work for the intended use as long as you hook the mainsheet up to the forward or middle holes only. If you get behind the main beam you definitely wont be able to tension it with the mainsheet properly.
The only thing that really worries me a bit is that there may not be enough room under the sail to get enough tension on the mainsheet. It doesn't look like there is a lot of room on the mainsheet to tension the sail. I'm not too worried about the tension in the foot, you can't really gauge it unless you are under load I'm more worried about running out of mainsheet to tension the whole rig. Is there any room at the top of the mast to raise the sail a few more inches? If so you should adjust your halyard so you are as close to the top of the mast as possible to buy you a few more inches. Also if you have any rake in the mast try and straighten it out. This will give you more room but could limit your adjustment ability to fix other performance issues.
I would try it out on the water before investing a lot of money or parts in it. Chances are with a few adjustments it will work fine. If you find it doesn't work well then you have a few options.
#1, rig a boom to it. Not as hard as you might think. You can get a swivel from another old Nacra then its just a piece of aluminum tube (2" dia by 1/8" wall will do) a couple of cleats pad eyes and some dyneema rope to make the connections and a workable outhaul. I can send you most of the parts (except the mast connection) for the shipping cost if you can wait til spring.
#2 buy a used sail. Maybe you can find a real 5.5 sail or you could even pick up the 5.0 sail pete has and that should work just fine (maybe a little underpowered) or even find a 5.7 sail.
#3, get the sail recut. Probably the trickiest option but if you find someone knows what they are doing it could be done.
#4, get a new sail designed. THat would likely be more money than its worth.
Google some Nacra 18 square pics, should answer boom questions. Looks like most of the boats used one,
bachoGoogle some Nacra 18 square pics, should answer boom questions. Looks like most of the boats used one,
Very early 18sq used a boom, and I believe later versions went boomless. It's difficult to figure things like this out when the Nacra models spanned many years, and were constantly evolving, especially since 18sq were a development class. I've looked at more 18sq photos on the internet than you can imagine - usually pictures of boats on the water from a distance and difficult to make out much detail, and most have a much more modern (square top) sail than what I have.
Anybody who has some good detail photos of boom setups on any Nacras, I'd love to see them. Like Wolfman says, I should probably sail it first as is before putting any money into further mods, but I can already tell the mainsheet angle and poor sail tension long the foot and elsewhere is going to bother me. I might go ahead and just make it a boom rig. The 20' stick of aluminum I bought for the beams (4" x 0.125) was only $100, so I'm guessing 6 or 8 ft of 2"x 1/8 or even 1/16th won't break the bank. Especially if kind folks have some fittings to send me! (thanks Wolfman).
Northern California
Wolfman, great info as usual.
QuoteSo the boomless rig should tension correctly. So that sail will likely work for the intended use as long as you hook the mainsheet up to the forward or middle holes only. If you get behind the main beam you definitely wont be able to tension it with the mainsheet properly.
On the most forward hole, as in the pic, the mainsheet is almost dead vertical, or perhaps just very slight rearward pull. It does weird things to the sail and doesn't look right at all. Obviously the boat will still sail, but I think it would drive me crazy.
QuoteThe only thing that really worries me a bit is that there may not be enough room under the sail to get enough tension on the mainsheet.
Quotes there any room at the top of the mast to raise the sail a few more inches?
I didn't pay a lot of attention to way up there unfortunately (the test rigging was fairly hurried, not only because it was 28 degrees out). I'm pretty sure though that the sail was raised to the max.
QuoteAlso if you have any rake in the mast try and straighten it out.
We guessed the hole position on the 10 hole chainplates, pretty much the middle, and found the stays too loose and the mast too vertical. So we went lower in the side stays, but didn't mess around too much since there were other things to test out (I was just happy the stays seemed to belong with this rig and were close enough). We need more tension still I feel, and more aft rake, so next time I'll put the side stays on the bottom holes and the bridle connections on whichever holes needed to get it tight. When making my new v-strap and cutting the beams etc. I deliberately wanted the mast rod and ball to only protrude from the main beam the minimum distance needed for stepping and rotation clearance, plus a bit. I ended up with about one inch of exposed threaded rod between the top nut and the bottom of the nylon ball (about right according to my veteran nacra source). Anyway. I see rather a lot of pics of mast rods extending waaaaaaaay out of the beam - several inches of exposed rod - mostly because the replacement rods were made longer than the originals to cater for all models, bigger and smaller. Anyway, in hindsight my nice low profile mast ball may have put some extra slack in the stays with the decreased height. Hopefully I can still soak this up and get the right rake. If not…. damn.
I digress. In the first photo, where you don't see much clearance, the main sheet is cranked pretty tight. I was seeing what would happen with the foot tension, and also checking out the mast bend. I think I'll be ok with enough clearance, although you have me wondering if it'll be a squeeze to get under the sail when going about, especially with a boom!
As for your suggested options, # 2, 3 and 4 aren't an option financially. Besides not doing anything at all, I think making a boom would be the cheapest option, and not overly difficult. Especially if you send me some parts! (thanks! - lets talk more once I have a solid plan for this boom design).
Quote#1, rig a boom to it. Not as hard as you might think. You can get a swivel from another old Nacra then its just a piece of aluminum tube (2" dia by 1/8" wall will do) a couple of cleats pad eyes and some dyneema rope to make the connections and a workable outhaul. I can send you most of the parts (except the mast connection) for the shipping cost if you can wait til spring.
Leaning toward this. Not concerned at all with the process of fabricating it, but more so finding the right parts and getting the dimensions and mechanics of it working correctly together. I realize its a pretty simple part once it's in use, but I like to do things right. I have seen google search images of various nacra gooseneck parts, but no detailed pics of them fitted to a boat, so I really can't visualize the attachment between boom and mast properly. I would prefer to go off the mast, not the main beam, since I'll sail with a partner most of the time, I want as much clearance from the tramp up front as possible.
Someone suggested a strop/loop of line *around* the boom and through an eye on the clew plate, directing the pull straight to the sail and not through the boom. This would allow for a lighter boom construction. I like it. But would I have just one loop, and pick one of the three holes to thread through, are have three loops (one through each hole) to maintain adjustability in the pull direction? I think I can almost answer my own question (one loop?) and that the outhaul will take the place of changing the sail shape (e.g. flattening it out) instead of changing the pull point or using a clew traveller (that's another thread icon_cool )
And the mast rotation wishbone - currently mounted facing forward (boomless). Would I need to remove and face aft with a boom? I basing this question on stuff I've read here previously. e.g. "All boomless rigs you want to induce rotation, especially off the wind. On rigs with booms the rotation is induced due to compression from the mainsheet on the boom, so you want to limit rotation"
I hope my questions don't seem to daft. I'm rebuilding a boat I've never sailed, and my last significant cat experience was 15 years ago!
Northern California
About as clear an image as I can find. This is a forum member's 5.2. Still can't quite make out the connection detail.
http://www.thebeachcats.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=35611&g2_serialNumber=4
Northern California
QuoteAnd the mast rotation wishbone - currently mounted facing forward (boomless). Would I need to remove and face aft with a boom?
Yes.
Will a 5.2 boom work for you?
The fitting that holds it to the mast is a fairly strong piece of kit, SS plate.
I have a spare boom & the fitting that joins it to the mast,(exactly the same as in the photo above) I can measure the boom for length, but the mast fitting is at one of my other houses...& I'm out of country til end of Jan.
The first factory 18 squares produced by Nacra were based on the 5.2 hulls but a later model used the hulls from the 5.5 .
I don't know if the 5.5 based Nacra 18 Square also used the same mast, if it did I would think the sail would extend further behind the rear beam the standard 5.5, but just guessing on that.
Factory Sails Sheet for the 5.5 based 18 Square.
http://www.thebeachcats.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=61736&g2_serialNumber=4
DamonLinkousThe first factory 18 squares produced by Nacra were based on the 5.2 hulls but a later model used the hulls from the 5.5 .
I'm aware the early 18sq used 5.2 meter hulls. Looking at the flyer, its clear that it used to be labeled as a Nacra 5.5, when that usually means something else now to most people (5.5 uni or SL) and we specifically refer to this guy as an 18sq. So the simple '5.5' decals on my hull and sail aren't entirely misleading. I just wish they'd added "CHOPPED DOWN" decals. Hey, that's a great name for my boat! haha!
Edited by sierracat on Dec 31, 2014 - 11:13 AM.
Northern California
Try it before you go to a boom. Chances Are it's fine. Off not , between Chris and myself we can get you set up with a boom proper. But it sounds like it should work.
D.
WolfmanTry it before you go to a boom. Chances Are it's fine. Off not , between Chris and myself we can get you set up with a boom proper. But it sounds like it should work.
D.
I don't want to make more work for myself… but I'm sure it needs a boom! I wish I had taken clearer photos from different angles. The main is not pulled aft by the sheet angle, period. With a bigger sail than the boat is meant to have (+20sq ft I think) I think I'll really need to be able to flatten the sail properly to depower. I used to enjoy going out in a good blow, and that probably hasn't changed.
The other issue is: I'm about to install the tramp, and more importantly, about to rivet the padeyes along the rear beam for the tramp. The angle of my beams is not fixed yet. That's why I put the mast and sail up as a test, before the tramp was ready. I wanted to check the angle of the mast rod against the mast rake, to rotate the main beam and get them in line, and I wanted to check the angle of the traveller to the sail for proper pull, and rotate the rear beam so that my tramp padeyes will be in the correct place.
I'm going to go ahead and rotate the rear beam a little aft, anticipating the boom addition before summer, and install my pad eyes and get this damn tramp on.
QuoteWill a 5.2 boom work for you?
Quotebetween Chris and myself we can get you set up with a boom proper
Chris/Dave, that would be great! I'll buy the tubing, but some fittings would be great to get hold of second hand - happy to pay and save a Murrays purchase.
Cheers guys.
Northern California
Quote I'll buy the tubing, but some fittings would be great to get hold of second hand
Why bother with buying tubing, then trying to cobble it together? I'll send you a 5.2 boom WITH all the fittings, mast attach/gooseneck, adjustable outhaul, cleats mounted etc.
I have 2 complete 5.2 booms assemblies.
Only problem, I'm in Hongkong as I type,(yeah it's 02:30am here) heading for Singapore in a few hours. Travelling through Cambodia & Vietnam for most of Jan, so I wouldn't be able to ship you any parts til then. I do have a bunch of photos on this computer, send me your email, (via PM, don't post it here) & I'll send you some, give you ideas if nothing else.
Edchris177
Hi Chris,
I was mainly thinking about the cost of postage. You are in Canada, correct? Also, I just assumed a 5.2 boom would be too short, given its a shorter boat with a smaller mainsail. But I have no way of confirming this. I'll try and unroll my sail and measure the foot, maybe that will give us a better idea. If we can figure all that out, then a whole boom would be awesome! Like I say, no sweat otherwise making my own if a small parcel of fittings can be sent economically. No hurry, I have all winter. I'll shoot you and email and we'll figure something out. Gotta run - three 1 year olds tugging at my leg! (how I ever managed to get this far on the boat I have no idea icon_cool
Edited by sierracat on Jan 02, 2015 - 12:52 PM.
Northern California
Hiya all,
If you have been following this, then the latest is that the tramp has been restitched (fingers crossed) and installed on the boat. The trailer is finished, except for lights, and the front upright for the mast (the rear upright is finished, and pivots down for boat unloading). Still need to paint my welds. Also need to remove what's left of the ancient hiking straps and install new ones (line through eyelets, with pipe insulation foam wrapped around them). Also had the upholstery guy make a simple pocket on the front of the tramp (the white thing in the pic) with a velcro closure, for stashing the main halyard and the righting line.
http://www.thebeachcats.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=112991&g2_serialNumber=3
http://www.thebeachcats.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=113033&g2_serialNumber=3
http://www.thebeachcats.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=113034&g2_serialNumber=3
I've committed to making this a boom rig (given the sail is an early 18sq and was made to have one) and because of the angle I chose for the rear beam/traveller, and the eyelet positions for the tramp lacing. No going back now. Boom is the last project on the list.
Working on the rudders right now. That's a whole other story. I'll start a new thread then post the link here.
Summer is coming!
Edited by sierracat on Feb 22, 2015 - 11:02 PM.
Northern California
Link to rudder thread:
http://www.thebeachcats.c…ms/viewtopic/topic/15476
Northern California
Finished! Maiden voyage last weekend was in very light winds, but enough to test everything out, and it went very well. Rigged quickly and without issue on the beach, and away we went. So happy to be done and looking forward to a great summer of sailing and exploring local lakes. Thanks everyone for you helpful input as I navigated this project.
Before: Dirty, damaged boat in pieces, as retrieved from a barn after sitting many years
http://www.thebeachcats.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=118772&g2_serialNumber=3
Almost done, weather warming up. Stay hydrated with some good homebrew.
http://www.thebeachcats.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=118755&g2_serialNumber=4
Maiden voyage, all that hard work about to pay off.
http://www.thebeachcats.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=118758&g2_serialNumber=4
After:
http://www.thebeachcats.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=118775&g2_serialNumber=3
http://www.thebeachcats.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=118776&g2_serialNumber=3
http://www.thebeachcats.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=118777&g2_serialNumber=3
Northern California
nice work. can you post a pic of your finished rudder system : tiller arm to cross-bar joint?
Jim Casto
NACRA 5.5 uni
NACRA 5.7
Lake Travis Austin TX
