Another rookie question. Hobie 16
I’m replacing my mast step that I broke as a rookie. When I ordered the replacement part, I also purchased a new 3 hole mast tang and a jib halyard pulley located near the bottom of the mast. The wheel was worn badly. The mast tang I have is a single hole which is very busy looking even with only one set of trapeze wires. I thought this would be a good time to replace these items at the same time. The mast plate “Kit” came with pop rivets. I think these are steel because it has some magnetic to it and is shiney. These pop rivets are 3/16” x ½”. My question is, when replacing the mast tang and jib halyard pulley, what type of pop rivets should I use? Should I find some like the mast plate ones I got? I’m thinking aluminum rivets would not be strong enough. I do have access to air and hand rivet guns but need to know what rivets are best for what I’m doing. Your advice, please. Thank you.
