I need some help from you experienced folks. I bought the NACRA 500 in August and love the boat. I have had the chance to take in racing about four times with mixed results. I’m slowly but surely making the transition from monohull sailor to cat sailor. One major issue that is slowing down my tacks is the fact that my battens are not popping over to the new tack after I tackor jibe in light to moderately light breezes (I would say 8 knots or less). I tack, get on the new tack and give the main a quick pump. Most of the time a majority of the battens pop over. However, the second batten from the top is not popping over. I’ve tried to pumping continuously but nothing happens. I found that the best way to get that batten to pop over is by trimming the main sheet super tight, the batten pops and then I ease. This would work on tack, but not so much on jibes. I have the batten tension relatively tight since the breezes were light. Do I 1) ease batten tension, or 2) fair or taper the batten.
Your help is greatly appreciated.
Mike
Laser
SR21
NACRA 500
