I have a 1982 Hobie 16 that I am slowly learning on. A couple of weeks ago I put it away for the winter and in the process I tried to drain the hulls. I tipped the trailer up until the rear cross member was almost touching the ground and a little water did come out. Then by looking at the hull shape I realized there was still a low section that was probably full of water yet. I made a very tiny LED light that was inserted into the drain hole and I was able to see water. So I took a wet/ dry shop vac and attached a small plastic tube to the hose and sucked every drop of water out of each hull. Checked it with the light; bone dry. I measured the water collected from each hull and came up with the following: Left Hull = 1gallon 2 quarts
Right Hull = 3 quarts
So my question is, is it normal to get this amount of water out at the end of the season? My thinking is that there must be some condensation taking place. The boat sits on a boat lift with the left hull getting the most sun. I do believe the hulls are tight but I will do a pressure check if the water collected is out of the ordinary.
Really appreciate any feedback on this.
