I use really thick tie-wraps, like these:
Only much thicker, like the ones they use as handcuffs .
Yank them as tight as I can with a pair of pliers, I just make sure the tramp is
evenly stretched, so all grommets have more or less the same load.
Then put the lacing-lines in a bucket of sweet water and when they are soaked
I reeve the line as hard as I can using a alu tube of 1" diameter and aprox. 1 foot
long, wrap the line around it and pull with 2 hands and all my body weight.
every 2 feet or so I use clamp like this
With a beek small enough to fit in the grommets, I clamp the line so I don't
loose tension. No worries about destroying the lace-line, the beeks have
soft plastic covers.
When I reach the last grommet I clamp the line and can prepare for the final knot
without losing tension.
When all lines are in place, I carefully cut all the tie-wraps.
Now, this way there is a lot of force involved, you could easily destroy the
tramp, so some common sense is required.
Regards, André
Edited by catmodding on Dec 01, 2014 - 09:37 PM.
Tornado (80's Reg White)
Prindle 18-2 (sold)
Dart 16 (hired and hooked)
13 mtr steel cutter (sold)
Amsterdam, the Netherlands
