When it's blowing i set the traveler out a few inches but it makes it hard to sheet in and out, because when i sheet in the traveler moves instead of shortening the mainsheet, resulting only in a waste of energy. I discussed this topic a while ago and even modifyied my traveler set up, which worked well except that it's more complicated to tack. To my needs it's still an improvement but I'm thinking in other options. One is to change the focus and drive with the traveler instead of the mainsheet. Set the twist with the mainsheet and handle the gusts with the traveler. I tried it but i realize that i would need more purchase to make it practical, which is totally possible. So the questions is if some of you focus more on the traveler than the mainsheet to handle gusts. On the previous discussion on this topic somebody suggested it and it makes sense. On that discussion i also learned that maybe the problem is that i sheet too far back (my crew won't take the main, it's my task). I tested moving a bit forward but it doesn't work.
I sail a N5.5 and don't race, just play around.
Thanks.
Edited by Andinista on Dec 16, 2014 - 05:48 AM.
