Fabricated a spi setup on my P 18-2, can't see any problems
to do the same on a P 19MX.
The spi-pole runs under the bridle, shouldn't be a problem with
a jib at all.
The life-span of a spi really depends on how you use it,
like bacho said, its easy to tear. So tape every shackle and sharp
object with vulcanising tape, set it and pull it in at a downwind angle.
I am now using my third spi in almost 5 years.
The first one got tangled round a shackle whilst hoisting , the fabric
is so light I never noticed I was shredding it.
The second blew in a big gust.
Overhere in the Netherlands, there is a big community of F18 sailors,
so its relatively easy to get hold of a second-hand spi.
Some points of attention,
the forward bridle to the spi-pole tack position. They attach to
the tips of the bows, reinforce the bow-tips by drilling a small hole
in it and eject some epoxy paste in the bow-tips for a more rigid
construction, learned this lesson the hard way.
The pull on the forward bridle, using a spi is quite force-full.
Assuming you want to attach the sheet-blocks for the spi to the
tangs of the back-stay, don't "fix" you're set-up straight away,
leave some slack in the front bridle so you can raise and lower
the spi-pole tip.
make it possible for the tack-block to move for and aft.
look for the best sheeting-angle by raising and lowering the pole
and moving the tack-block . Once found, fix it permanently .
Hope this helps, André
Tornado (80's Reg White)
Prindle 18-2 (sold)
Dart 16 (hired and hooked)
13 mtr steel cutter (sold)
Amsterdam, the Netherlands
