Cleaned out the area - I used a razor blade, flat tip, and other torture devices to get anything lose out.
used some 50 grit inside and around the area.
blew it clean with compressed air
![http://www.israeltour.com/images/rudder-1.jpg](http://www.israeltour.com/images/rudder-1.jpg)
Created a pocket in the rudder and made an epoxy insert (west system w mill fiber and colloidal silica filler) - dry fit, add lots of thickened epoxy inside first, then pushed in the insert. epoxied everywhere...
![http://asnstudios.com/images/rudder-repair-2.jpg](http://asnstudios.com/images/rudder-repair-2.jpg)
used a dremel and got it close to the right shape (the board didn't need lots of shapping, most of the work was internal)
![http://asnstudios.com/images/rudder-repair-4.jpg](http://asnstudios.com/images/rudder-repair-4.jpg)
faired in the epoxy to shape, and then some gel coat in some small areas and chips
![http://asnstudios.com/images/rudder-repair-6.jpg](http://asnstudios.com/images/rudder-repair-6.jpg)
later painted with spray paint to match rudders :)
Then came the centerboards - they were 2" different length -
![http://asnstudios.com/images/foil/7.jpg](http://asnstudios.com/images/foil/7.jpg)
created a pocked and an epoxy wedge. dry fit it and then epoxied the snot out of it
![http://asnstudios.com/images/foil/8.jpg](http://asnstudios.com/images/foil/8.jpg)
I have card-board cut out templates / outlines of a properly sized rudder and a good center board that i use as templates
I sailed on these this weekend, More pics to come - more work to finish them up too
Edited by MN3 on Feb 23, 2015 - 06:39 PM.
